#31 |
Liked 837 Times in 164 Posts
The ARC module is already spelled out as being prohibited in Sportsman categories. I can’t imagine any sort of “traction control” being very consistent. Killing power, especially if trying to replicate a curve, may be too “stop and go” for it to work well in a bracket racing scenario.
1189 F/SA Defunzalo Racing Enterprises |
#32 | |
Liked 448 Times in 98 Posts
I have been around long enough to remember the old adage "your not cheating if you don't get caught". We all know its self certification on entries and cars rarely get looked at closely anymore. That said, I think the vast majority of racers do not intentionally cheat. Last edited by DG; 01-25-2024 at 06:52 PM. |
#33 | |
Liked 564 Times in 66 Posts
Put up, or… |
#34 |
Liked 759 Times in 379 Posts
#35 |
I see the flaw in my statement. I guess it really depends what is really defined as "traction control." I would put it into 2 categories, active, and passive traction control. I would consider time based timing retards to be passive. They are either programmed into the msd box, or the ecu. With these, the timing curve will be exactly the same every run, which has proven to be very consistent for many cars that use a setup like this. What I can't imagine to be super consistent would be a type of "active" traction control, where the msd or ecu is responding to wheel speed. I know that computers have come a long way, but the response time of something like this may not be quite fast enough for it to work with absolute accuracy. Correct me if I'm wrong, and I'm sure you will, but I've never heard of someone using an arc module or something similar that does the work of a "matty box" for you, and replicates runs with accuracy by changing the tune of the car going down the track.
1189 F/SA Defunzalo Racing Enterprises Last edited by Doug Hoven; 01-26-2024 at 09:23 AM. |
#36 |
Liked 2,717 Times in 957 Posts
Remember when it was about cutting a good light and running your dial? The only external wiring was for the Line Lock.
#37 |
Liked 7,701 Times in 1,734 Posts
It COULD be that way again but I won't hold my breath waiting.
#38 | |
Liked 1,919 Times in 576 Posts
Dont feel bad. I had to look that up too. I had no idea what the ARC module did. I guess I am old school. If I cant win without electronics or cheating then I dont get to. My deal is to cut a light and run the dial. I work real hard to do that. I am not a "hitter" but I do go some rounds and have finshed top 10 in the division 2 out of the past 4 seasons. I also had a divisional win in 22. Personally I dont think there is many out there cheating.
Mike Pearson 2485 SS |
#39 | |
That said, I have no first hand knowledge of the matty box and neither does anyone else that isn't/hasn't used it and they ain't talking about it no mind doing so on a forum but I am well aware of what can be done with the ARC module and if the question is can it be used for to make your car deadly consistent? That answer is YES and by deadly, I'm not talking hundreds, I telling you thousands from pass to pass but again, the best of the best bracket cars do this also without an ARC module. start at 8:54 Last edited by 1320racer; 01-26-2024 at 10:49 AM. |
#40 | |
