Old 01-13-2024, 07:09 PM   #11
David Lee
Liked 346 Times in 126 Posts
Default Re: New laptop
both dell and hp have good laptops from low end user to high end. just like everything. you get what you pay for. i would stat away from the low end
Old 01-14-2024, 01:21 PM   #12
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
my experience has been mixing work and racing on my laptop has always led to problems .
I finally went to a dedicated factory refurbished Lenovo think pad with a SSD for racing use only ,and did not need to spend a fortune on memory or power I did not need . ..Run on windows 10 , rarely bother with updates because I don't use it on the internet except to update Crew Chief. Been reliable for several years
Freed up money to buy a good unit for work.
Old 01-15-2024, 09:22 AM   #13
Run to Rund
Liked 56 Times in 29 Posts
If you plan to carry it around a lot, you will appreciate the light weight of the LG Gram laptops.
Old 01-15-2024, 12:16 PM   #14
340Cuda
Liked 805 Times in 341 Posts
Another recommendation, I don't think I would purchase a laptop or a desktop that did not have a SSD (solid state drive) as its primary storage device.
Old 01-15-2024, 02:32 PM   #15
Jeff Niceswanger
Liked 1,072 Times in 379 Posts
Another thing. Make sure the unit your buying is using the traditional USB Ports...the old style. A lot of the nicer ones are switching over to the mini, and you will have to use a dongle adapter to hook up to your Big Stuff/Holley/Msd etc.
One of my laptops, a solid state drive Dell XPS-15 is wonderful, except it's full of those mini ports and is a pita.I have a couple year old identical traditional drive XPS-15, and it's still the old bigger ports. I end up using the old one most of the time
Jeff Niceswanger 3740 SS
Old 01-16-2024, 09:30 AM   #16
Eddies66
Eddies66's Avatar
Liked 881 Times in 452 Posts
Sorry guys but I have had an Apple product since the mid 80s starting with the Apple II E. Use an iMac daily and just purchased a MacBook Pro for Christmas. I don't even know if I could work with Microsoft programs.
Eddies66 is offline   Reply With Quote
