Old 01-11-2024, 11:50 AM   #1
rboyle
rboyle's Avatar
Liked 598 Times in 164 Posts
Default Garage clean out
New in package MSD 2 step module $75
Used MSD low RPM chip set 3000-7000 rpm in holder pack $150
Used MSD high RPM chip Set 7000-11,5000 RPM in holder $150
New Meziere BBC water pump with reservoir built in $400
Used MSD degree chips from 2-10 degrees in Tavia Holder $60
Racepak Card cartridge Reader and 2 cartridges $300
New Racepak vnet air/fuel controller single channel $425
New Biondo Pro Bandit shifter Electric Solenoid $135
New C&R chiller check valve for radiator hose $250
Holley Alcohol Jet Kit $100
Digital Delay Mega 450 delay box used for display only $350
Enderle Alcohol Mechanical Fuel Pump with regulator, fuel log, and lines $750
Stinett Dominator from S/C dragster set up to work with throttle stop. $1000
Under carb throttle stop, scoop mount and everything $350
8, 1.6 Harland Sharp Roller Rocker Arms SBC $150
Guide plates, studs, poly locks and stud girdle for SBC $175
Turbo Start battery Charger $225
Rich
631-461-6761
