Thread Tools | Search this Thread | Display Modes |
Liked 5 Times in 4 Posts
Selling all of this for a friend!
Patterson Built 327 Engine For Sale Allan Pattersons personal engine! 250 Horse Low Compression Combo 40 Runs from All Brand New 1 Second Under in GT/TD, 11.30 Index Bowtie Block Bullet Crank Manley Tour Lite Rods CP Pistons Jesel Belt Drive Jesel Rockers Jesel .904 Lifters Jesel Front Mount Distributor Bullet Cam New Hettler 520 Heads Hettler Intake 4GC Carb MSD Crank Trigger MSD HVC Coil MSD Distributor Plug Moroso Wires Meziere Water Pump CSR Starter $26,500 ProTrans 2.40, 1.54 Trans. Clean neutral. 44 runs from brand new. Serial Number 10403. Comes with a Precision Shifter, cable and brackets. $5500 Coan 7 inch Aluminum Bolt Together Converter. Also has 40 runs on it. Set up for the 327 Listed above. $3000 Have pictures of everything and will make a package deal on all of it! Thank you for looking and contact me for any info! 440-396-0568 Matt Dadas |
#2 | |
Liked 114 Times in 29 Posts
The transmission, is it reverse pattern also? Is it still available? Thanks. Jason |
