Old 11-10-2023, 01:39 PM   #1
MDadas
Liked 5 Times in 4 Posts
Default Patterson 327, ProTrans and Coan Bolt Together For Sale
Selling all of this for a friend!
Patterson Built 327 Engine For Sale
Allan Pattersons personal engine!
250 Horse Low Compression Combo
40 Runs from All Brand New
1 Second Under in GT/TD, 11.30 Index
Bowtie Block
Bullet Crank
Manley Tour Lite Rods
CP Pistons
Jesel Belt Drive
Jesel Rockers
Jesel .904 Lifters
Jesel Front Mount Distributor
Bullet Cam
New Hettler 520 Heads
Hettler Intake
4GC Carb
MSD Crank Trigger
MSD HVC Coil
MSD Distributor Plug
Moroso Wires
Meziere Water Pump
CSR Starter
$26,500
ProTrans 2.40, 1.54 Trans. Clean neutral. 44 runs from brand new. Serial Number 10403. Comes with a Precision Shifter, cable and brackets.
$5500
Coan 7 inch Aluminum Bolt Together Converter. Also has 40 runs on it. Set up for the 327 Listed above.
$3000
Have pictures of everything and will make a package deal on all of it! Thank you for looking and contact me for any info! 440-396-0568
Matt Dadas
MDadas is offline   Reply With Quote
Old 11-12-2023, 09:38 PM   #2
Jason Shepard
Jason Shepard's Avatar
Liked 114 Times in 29 Posts
Default Re: Patterson 327, ProTrans and Coan Bolt Together For Sale
Bowtie Block
Bullet Crank
CP Pistons
Jesel Belt Drive
Jesel Rockers
Jesel .904 Lifters
Bullet Cam
Hettler Intake
4GC Carb
MSD Crank Trigger
MSD HVC Coil
Moroso Wires
Meziere Water Pump
CSR Starter
$26,500
$5500
$3000
Matt Dadas
The transmission, is it reverse pattern also? Is it still available? Thanks. Jason
Jason Shepard is offline   Reply With Quote
