Old 10-23-2023, 04:06 PM   #1
Don Kennedy
Liked 902 Times in 237 Posts
Default Need some help on My new truck
I have a 1997 Gold rush Trailer and I am in the process of buying a new crew cab dually and does anyone have experience or a simple solution to use the Jaws welded on the trailer to use with a pin on the new truck Bed ??
Don Kennedy 7701 SS
Old 10-24-2023, 06:59 AM   #2
Liked 10,681 Times in 2,222 Posts
Default Re: Need some help on My new truck
Try Trailer World in BG Ky.
Old 10-24-2023, 08:55 AM   #3
Don Kennedy
Thanks Larry I found a King Pin adapter for trailers with inverted 5th wheel hitches I think it will work on my new Dually with the towing package hole in the bed,
Don Kennedy 7701 SS
Old 10-27-2023, 08:20 AM   #4
Don Kennedy
This is my issue now I need a simple King Pin that will fit in my new truck Puck OEM system I do not want to cut off my Gold rush jaws on my trailer < I do not want to add a new system to the bed all i want is a simple way that a king Pin that will fit in the oem puck system on my new crew cab dually if any one has a solution or can make me a king pin witha plate on it that will fit down into the puck system give me a call 602 284 6240
Don Kennedy 7701 SS
Old 10-27-2023, 12:37 PM   #5
cad
cad's Avatar
Liked 91 Times in 51 Posts
Have you reached out to B&W, yet? I dont even think they make the square bed adapter to inverted kingpin anymore. If I buy a newer truck, I will likely have to convert my GR inverted to a gooseneck ball.
Clark
cad is online now   Reply With Quote
Old 10-27-2023, 11:06 PM   #6
Don Kennedy
Clark
I could not find a answer so I am going to convert my Gold Rush to a goose neck
Don Kennedy 7701 SS
Old 12-13-2023, 11:36 PM   #7
cad
cad's Avatar
Originally Posted by bigsapper View Post
Look into a custom adapter plate to connect your '97 Gold Rush Trailer with those Jaws to a new truck bed. It's a neat solution that allows you to join the Jaws on your trailer without much hassle with the pin on your truck.
Do you have a link?
