Old 10-10-2023, 06:42 PM   #1
Gregg Luneack
Liked 225 Times in 30 Posts
Default Pro trans--powerglide parts
1- NEW Pro Trans F front planetary 26/58 2 runs $500
1-NEW Pro Trans # 6 rear planetary 36/70 2runs $500
1-used Pro Trans #6 '' '' '' $300
1-New 904 trans Mopar Perfomance deep pan $50
1 used 904 2,75 1st gear set , this is Mopar not Pro Trans $275
1-New 10'' Pecision Industries 3000 stall street/strip converter, 727 BBM $300
1-rebuilt 727 BBM transmission, deep pan, manual valve body $750
1-New B&M Super Cooler trans cooler $75
1-used ACD air shifter,with air bottle older unit $250
1- used B&M PRO RACHET shifter with cable $250
1New B&M shifter cable 4 ft long $45
1-NEW B&M shifter cable, 5 ft long $50
!-NEW ATI 12.625 long PG input shaft $50
1-NEW TCI 12,875 long input shaft $50
1-used PG to Turbo input shaft $150
1+used PG aluminum pan $50
2-ATI 208,straight cut gear sets, broken pinion gears $50 760-630-9094, no text
Gregg Luneack is offline   Reply With Quote
Old 10-12-2023, 01:40 PM   #2
GTX JOHN
Liked 2,516 Times in 701 Posts
Default Re: Pro trans--powerglide parts
I will take the Shifter cables.
John Irving
741 Stock
741 Super Stock
