Old 10-01-2023, 04:14 PM   #1
darrellbargeron
Default Super Stock GT Rules?
I have a 1968 Dodge Dart that is backhalved with a 9 inch Ford rear. The front k member has been replaced with a tubular k member but still has the std steering box. My question is: Is it legal in super stock to run a tubular k member in a car like this in the gt classes? Or is that only allowed with the front wheel drive conversion cars?
Thanks Darrell
darrellbargeron is offline   Reply With Quote
Old 10-01-2023, 08:30 PM   #2
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Default Re: Super Stock GT Rules?
Stock K member required, but it can be modified for oil pan etc.
Old 10-02-2023, 12:13 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
Sit tight.. A little bird has chirped about that rule being changed.
If it happens it will be in the 2024 rules.
Make your decisions after the 2024 rules are released.
I think it might be an effort to equalize the rules between the FWD conversions and the RWD SS/GT cars.
Adger Smith (Former SS)
Old 10-02-2023, 12:34 PM   #4
Rory McNeil
Concerning the back half, it may or may not be legal for Super Stock , depending on how it was done. The rear frame rails are not permitted to be higher than the factory trunk floor, and most of the original trunk floor needs to be retained. So if the car has had all the trunk flooring replaced, or made of flat steel or aluminum, and had the frame rails made to "kick up" higher etc, that will need to be corrected to meet the rules.
NHRA 6390 STK
M/S 85 Mustang
Old 10-02-2023, 01:03 PM   #5
Jim Caughlin
Liked 807 Times in 247 Posts
A legal Super Stock back half is way different from a generic back half. As Rory states, it needs to be mostly not only steel but also mostly original floorpan. Any suspension retrofit need to be contained under the original floor, a work around on that is that it can be contained inside the new steel tubs. Way more complicated than a generic back half. On the other hand, I have seen some massively illegal back halves hiding under carpeting and no one is saying anything.
Jim Caughlin is offline   Reply With Quote
Old 10-03-2023, 08:28 PM   #6
MAURICE BLENDHEIM
Liked 286 Times in 88 Posts
Smile Re: Super Stock GT Rules?
They must be East Coast Cars, out West it's all by The Book. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 10-04-2023, 03:52 PM   #7
darrellbargeron
Hopefully these pictures attached correctly. Does this look like it would be legal. Ignore the spider webs and dust, it's been sitting a couple of years...
Well I tried uploading a picture of the trunk but it keeps failing. Apparently the file is too big or to high of resolution.
Old 10-04-2023, 07:44 PM   #8
CMcAllister
Liked 931 Times in 265 Posts
Stock/original floor, in the original location, between the frame rails. All the way to the tail panel.
Old 10-26-2023, 07:01 AM   #9
al wisniewski
Adger, would it be for all GT cars or Super/stock in general? Thinking Chevy II's could stand an update?
al wisniewski is offline   Reply With Quote
Old 10-26-2023, 01:08 PM   #10
340Cuda
Liked 805 Times in 341 Posts
Not Adger, but my guess is that it would be for GT only to help level the field between the FWD conversions and the cars that are RWD stock.
Bill
