Old 08-29-2023, 02:18 PM   #1
Hefler
Liked 4 Times in 3 Posts
Default 283 Stocker engine/trans,rearend and etc. for 1957 Chevy.
If your looking for a easy and economical way to put your 57 Chevy or build a car to put into NHRA stock eliminator here you go..
More description in the photos link below.
This is for the complete engine, transmission/converter, shifter, complete Moser rearend.
The engine factory 220hp NHRA rated 215hp) is complete from carb to pan, dist., starter, flexplate , water pump and alternator…. Just put coil wire on and plug in distributor and go.
Powerglide trans with 2.18 low gear and A-1 torque converter with roller bearing tail housing.
Mid trans mount and rear trans mount.
Precision performance shifter.
Complete Moser 12 bolt with 5.86 gear, 35 spline spool, axles with 5/8 studs,1350 yoke,Moser disc brakes and driveshaft.
Rear leaf springs
Fenderwell headers with collecter tethers.
Car ran 12.84 on the 13.15 index (O/SA) but needs some tuning and possibly have the converter loosened up.
Low runs on everything.
Priced to sell at $14.5k For everything listed above Everything is still in the car.
Front and rear wheels/tires available as well.
Call/text 817 521-5333
For photos/detailedinfo please click on the link below.
https://www.racingjunk.com/stock-sup...-headers..html
Hefler is offline   Reply With Quote
Old 08-31-2023, 08:38 PM   #2
Randy Guest
Liked 28 Times in 15 Posts
Default Re: 283 Stocker engine/trans,rearend and etc. for 1957 Chevy
Are you selling the cal trac bars and shocks and the front springs.what wheels do you have for it. thanks
Randy Guest is offline   Reply With Quote
Old 09-02-2023, 02:11 PM   #3
lewis Becker
Liked 20 Times in 9 Posts
please contact Lew becker -570-284-7763 ,e.s.t.,in central pa. thank you.
lewis Becker is offline   Reply With Quote
