Old 08-18-2023, 11:36 AM   #101
Billy Nees
Liked 7,907 Times in 1,754 Posts
Default Re: Roller Cams in Stock Eliminator?
Originally Posted by john ancona View Post
I still seem to be hearing the same story about flattened cams ,and ruined lifters form many
along with engines that have been ruined , so it's not just two of us supporting that something be done
Umm, roller lifters break too!
Billy Nees 1188 STK, SS
Old 08-18-2023, 12:02 PM   #102
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
This roller cam thing is like beating a dead horse.
There are plenty of racers that are having success with their solid cams. Using roller cams will not help the class at all. Call the cam company of your choice and tell them you want a roller lobe for your 450 lift application. I know someone with a foxbody that cam stock with a hydraulic roller and wanted to upgrade to a solid roller. He was told no lobes are available and it would be alot of money to design a lobe to use. By the time he was done, it was gonna be 3k to put one in the engine. I'm surprised some of you are gonna spend more time trying to lobby for a roller cam instead of just putting a solid cam in.
There will be 150 cars at Indy in stock, and there are more than 45 with solid cams. The 30% number is fake news!
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 08-18-2023, 12:03 PM   #103
Bill Grubbs
Liked 573 Times in 67 Posts
Suggestions are what is needed for sure ,I am not going to speak for Terry or any others,
I have said in the past on here the reasons as to why a change is needed , for my self I have been racing NHRA for 50 plus years now like many of my friends have, I still seem to be hearing the same story about flattened cams ,and ruined lifters form many
Not calling you out, but John you don't speak for me either.
JMHO...Keep Stock...Stock!
While we cannot undo past changes... we do have the ability to stop future changes!
As far as lifters are concerned, we toasted a SS engine first rnd of qualifying at Denver. We had a lifter go bad and take out a camshaft. The full extent of the damage has yet to be determined. At best it is a lifter, a reground cam, and a pushrod. At worst...we shall see.
This was a $$$$ lifter. **** Happens. We have not had a stocker lifter go bad since 2007 (knock, knock, knock...knock on wood) and that was a Schubeck lifter which exploded on startup. We have now had two roller lifters go bad in the last 5 years. If your having lifter issues, then fix the issue...don't change the rules! We found our issue for the first SS failure...it was an issue put in place by a now closed engine builder in the Houston, Texas area. The current issue appears to me to be a bearing failure. we will determine whether it is a material failure, or if the failure was caused by some other issue within the engine. Either way, I have complete confidence any future failure will not be for the same reason.
I do not believe in the concept of "One person ****s their pants...everybody wears diapers!"
Bill Grubbs is offline   Reply With Quote
Old 08-18-2023, 12:12 PM   #104
1347
1347's Avatar
We need Bubskis input on this rule change proposal!!!
Duane Hoven
1342 SS/GT
Old 08-18-2023, 12:27 PM   #105
Billy Nees
Bill! Why do you have to keep bringing that up! I TOLD you it was an accident!
Old 08-18-2023, 01:19 PM   #106
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
When a roller lifter that has roller and not a bushing breaks it can get very expensive. Also rollers increase the lifter bore side load and some old blocks may have a problem with breaking lifter bores.
Stan
Old 08-18-2023, 01:35 PM   #107
john ancona
john ancona's Avatar
Liked 187 Times in 58 Posts
Some how you ,and others think I am speaking for all of Stock Eliminator when in fact as I said on the site many times there are those of us in my circle of friends of witch you and others last time I checked are not included , look I run stock ,and super stock
so there is no need to say I am trying to change Stock as I am in the crowed that voiced my opinion many times over the years right to NHRA at Pomona in person with many others about all the changes over many years with that said ,I have yet to hear any body say oh we will remove any of the changes on my car up to this point ,but there are those on here that are quick to say keep Stock Stock that have all the changes on there cars
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
Old 08-18-2023, 01:39 PM   #108
melvin wellman
Liked 2 Times in 2 Posts
I know this is no help. But back around 1981 McCandless was selling the cam dynamics cheater cam for 25 bucks. I got one and some 40 dollar lifters from the local auto parts store. This was in a 440 and it really woke that thing up. I know things need to evolve, but that was a fun experience with no drawbacks. I ran that thing for a long time and never had any wear issues. Like I said, no help, just seemed a bit simpler at the time.
melvin wellman is offline   Reply With Quote
Old 08-18-2023, 02:00 PM   #109
Doug Hoven
Liked 869 Times in 165 Posts
I know this won’t happen either, but what about putting some sort of valve spring pressure rule into place? Maybe if one didn’t have to, or wasn’t allowed to, run so much spring pressure to keep their valvetrain under control with a radical cam lobe , they won’t wear out camshafts and lifters every other season.
1189 F/SA
Defunzalo Racing Enterprises
Old 08-18-2023, 02:48 PM   #110
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
That's cheap compared to $2200 for tappet lifters, $1200 billet cam, and EVERYTIME you start it wondering if this is the run it eats a lifter and cam up on. Maybe 40% is a better number. Still a big disadvantage running tappet over the newer stuff and if you don't wanna run it no one is forcing you to.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
