Liked 242 Times in 81 Posts
A question for you gentleman that tow with a stacker across our horrendous roads. How much clearance do you need between the roof of the car and roof of the trailer? Best tie down options? I have seen the posts of cars getting loose in the trailers.
Thanks for any input.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
Liked 66 Times in 31 Posts
I see that no one has answered your question yet. I have never owned a stacker but I can tell some stories from some friends. A friend had his girlfriends car on top because she didn't want to drive back home and when he got home the roof was caved in. He thought it had plenty of room. You have to think about what's going on in that trailer when it's bouncing down the road. The car is not the only thing that has to be tied down. The lift can bounce too if not tied down.
Liked 341 Times in 67 Posts
I can tell you what doesn't work. 4 inches is not enough clearance in mine. I have found no commercially available tie downs that don't slide. My 30 year old ones work best.
They seem to be made out of a material that has a higher coefficient of friction, I don't use dollar store tie downs. Without mentioning brands. I have two of the best brands and they still slide. Cross straps or straight seem to make no difference. That top car is moving around a lot. The best advice I have gotten is have at least 3 turns of material on the strap and check it every time you stop. I use 4 straps on the top car. That helps a lot. I am thinking of having custom non adjustable one made for the rear. I put a lot of miles on my stuff on some really bad roads. I haven't had one come loose, but My car has some scars from close calls. |
Liked 15 Times in 6 Posts
Give me a call tomorrow and I will share my seven years of experience with stacker. Have hauled SS\AH, stocker Camaro, COPO, and Cobra jets.
All have their own issues when on the lift. You can try me at 716 five 5 three zero 9 89. Best after 3pm east coast Bill Kraft |
Liked 974 Times in 310 Posts
Turnbuckles and chains don't stretch .
Liked 565 Times in 70 Posts
My rule of thumb is about 8 inches.
If you tie the car down in the back by the frame rather than the rear end housing it helps a lot. The biggest problem I've encountered is the car on top wants to move sideways. I chock the front AND rear wheels to prevent this. Hope this helps |
Liked 3,227 Times in 981 Posts
Combined with Larry’s approach after his Dumbo experience I’ve never seen a better response to a request for info, apparently SSDiv6 doesn’t use a stacker or it could have even scored higher. If Ed Wright (RIP) could have responded it would have been perfect.
Jim Carter 2340 Super Stock 2340 SST/2340 Stock Set another place at the table Last edited by jmcarter; 07-18-2023 at 10:32 AM. |
#8 | |
Liked 5,144 Times in 1,964 Posts
I just never liked compressing expensive racing springs for days or weeks at a time. You know the new car transporters chain the frame and crank them way down for clearance and stability. May be okay for your new car, on a one time basis ;-) I think maybe crossed straps on the housing and then maybe snap on a couple of safety hooked chain to limit any upward movement..Just a thought..
#9 | |
I always cross strap all cars. The cuda has traveled close to 400,000 miles tied down as I described and my dusters probably half again as much.... but I bow to your experience. |
#10 | |
Just my opinion :-) Should have mentioned, I cross my straps too, in some applications. I had MJ make me some vinyl wrap- around velcro sleeves to keep the straps from wearing against each other. Marky ;-)
