Liked 997 Times in 201 Posts
Got a sbc engine on my run in stand. Have a complete digital 6al, blaster 2 coil ,85551 distibutor. Start up the engine and it idles for a few seconds and then it starts exploding out of the exhaust like a string of firecrackers. Timing is ok. Put a stock HEi in it and it runs fine. All wires are isolated for no interference. Anyone ever experienced this before?
Liked 1,034 Times in 368 Posts
I've had 2 MSD rotor buttons burn thru the bottom and cause identical issues. Rotor looks new on the top but they burn right through the bottom. Have a look, it only takes a second. I think they re designed that rotor a while back to help this issue.
Jeff Niceswanger 3740 SS |
Tried a couple new rotors, same results. Tried numerous new, used boxes coils. Same thing. Got thru to some one at MSD they said it has to be something in the pick up. Same results with a new distributor, and a previously good used one.
Liked 974 Times in 310 Posts
Same ignition wires between the two distributors ?
Liked 71 Times in 23 Posts
Had a friend bring me his race car that was doing the same thing. What I found was, he had replaced the pick up coil and put it in backwards and that caused reverse polarity.
Monte Howard 3209 STK, 3208 SS |
Yes if you reverse those wires on the pick up it will advance the timing 12 degrees and then it will back fire thru the carb. This is all thru the exhaust. MSD rep told me the only way I will get that extremely loud banging thru the exhaust is having the timing retarded. I have had 3 different distributors in it. With the HEI set up in it the motor just sits there and purrs. Thanks every one for the info. Will let you know what I find out. If I ever do .LOL
Liked 456 Times in 148 Posts
I assume you replaced the distributor cap as well as the rotor?
Just recently a new MSD cap was purchased and installed misfiring occurred. Put the old one on, ran fine. Steve Teeter Stk/SS 620 |
Changed a few more components in the ignition and the problem finally went away. Thanks for all the suggestions.
Liked 314 Times in 113 Posts
And the component that caused the problem was?????
Larry Merk |
Liked 66 Times in 31 Posts
Suspense is killin me.
