Old 06-17-2023, 05:19 PM   #31
Jim Bailey
Liked 584 Times in 94 Posts
Default Re: SFI flexplate mandatory in all v8s Jan 2024
Never had any problems with any SFI certified Mopar Flex Plates "UNTIL" I started to two step. We're our own worst enemy. If you two step, the flex plate must become a part of your service routine. Just saying .........
Jim Bailey is offline   Reply With Quote
Old 06-18-2023, 12:03 AM   #32
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Did it crack or explode.
Old 06-18-2023, 08:17 AM   #33
4543
Liked 649 Times in 140 Posts
I’m not sure if it’s the 7000 rpm or the converter hitting at 5800 instead of the 4400 people used to use! I think the converter hit stresses the flex plate more than going down the track but it could crack at the hit and come apart down track. The stock GM flex plate that I saw has the ring gear only welded on one side. The certified appears to be welded on both sides of the ring gear and possibly more welds. Both of mine are certified but have been in my cards for years. I’m thinking I’m going to replace them. Mike McMahan 2543 H/SA
4543 is online now   Reply With Quote
Old 06-18-2023, 08:23 AM   #34
Billy Nees
Liked 7,889 Times in 1,753 Posts
Now just to be "fair", this ruling is going to apply to all V8 bracket cars also right?
Billy Nees 1188 STK, SS
Old 06-18-2023, 08:26 AM   #35
Jim Bailey
Lightbulb Re: SFI flexplate mandatory in all v8s Jan 2024
Paul, never had one come apart. Had several crack near the convertor bolt holes, but caught it.
Old 06-18-2023, 08:26 AM   #36
MR DERBY CITY
Liked 8,220 Times in 1,538 Posts
Better be careful Mike, Old Chinese philosopher Confucius sez older flexplates made in USA might be stronger than newer flex plates made in CHINA ….
Old 06-18-2023, 08:29 AM   #37
Shake & Bake
Liked 37 Times in 33 Posts
Thumbs up Re: SFI flexplate mandatory in all v8s Jan 2024
Thats why I buy a Meziere flex plate. I go thru between 8200-8300 rpm on the big end..... Not saying I will never have an issue, but I haven't as of yet. Been running one for quite some time now.
Shake & Bake is offline   Reply With Quote
Old 06-18-2023, 09:30 AM   #38
Chevy55
Banned
Liked 179 Times in 89 Posts
2023 NHRA RULE AMENDMENTS
Beginning January 1, 2024, SFI 29.1 flexplate mandatory on all V-8 vehicles. Any car running quicker than 9.99, SFI 29.1 automatic transmission flexplate and SFI 30.1 flexplate shield mandatory. See General Regulations 2:12, 2:14.
Chevy55 is offline   Reply With Quote
Old 06-18-2023, 11:20 AM   #39
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Having repaired several racers cars after a flexplate explosion I cannot understand why anyone would be against this rule which should have been in place years ago.
I've seen headers sliced off, frame rails cut in half and floors with shrapnel sticking thru within inches of the drivers feet. . Not to mention the possibility of severe injury to track personell or even your crew menbers.
Jim Bailey is correct . the 2 step is well known for causing other issues like broken oil pumps and pickups..
Old 06-18-2023, 11:49 AM   #40
Liked 5,150 Times in 1,966 Posts
Yes..Okay.
So how does that apply to U/SA 273 Mopars?
