#11 |
Liked 772 Times in 192 Posts
Adger -
Quoting a dear and common friend of ours, "What is legal is what passed tech." My Camaro was a '67 so I never tried the spoilers. I even ran the OEM 4-piston disc brakes when it was raced as a Z28. It's kinda like hoping the psychology of having the obvious cheating areas clean they won't continue looking. Bob Ayres also taught me to have something very obviously wrong (but easy to correct) when you go through tech so they will stop looking after they "Gotcha!".
#12 |
Liked 544 Times in 213 Posts
My good friend and co-worker was running C/SM with a '69 Camaro in the late 70's and at the Etown Summernats was told by Tech he was fine with just the front spoiler. At the scales after a run a guy I only knew as Joe Tech said he was DQ'ed if he did not have both front and rear. A call back and forth and some discussion with various people he was allowed to run with just the front.....and I don't recall the issue ever coming up again.
#13 |
Liked 2,626 Times in 950 Posts
The late great Dave LeBrun didn't have spoilers on his Camaros.
#14 |
As a final anecdote on the gen 1 Camaro spoilers, for most of two seasons before I built the '67 stocker I drove a '67 Camaro E-F/MP car that the owner had installed front and rear spoilers on. This was a 130mph car, much faster than the 100mph stockers I was used to driving. I got him to allow me to remove the spoilers for a while and made approximately 15-18 passes without the spoilers over three weekends. It's hard to say about the ET, but the MPH was easily .7-1.4 faster. In the end he put the spoilers back on because "he liked the way it looked." ??? I didn't last much longer with that arrangement.
#15 | |
#16 |
Liked 42 Times in 17 Posts
Kind of off topic but still related to 69 camaros. It's my understanding the 850 carb on a ZL1 didn't have a choke on it from the factory, correct? If so, why does nhra make it mandatory?
#17 | |
Liked 988 Times in 272 Posts
Where is the info that they had no chokes?
Duane Hoven 1342 SS/GT |
#18 |
I was reading an article about the #1 & #2 zl1s getting delivered of the truck and they couldn't get them started because it was cold outside and there was no choke. But you're right, after doing more research there was a choke plate but apparently it wasn't hooked up from the factory. It's tough to get legitimate info on some of that stuff. Sometimes it seems it's easier to get info on older cars from people on here instead of Google.
#19 |
Liked 330 Times in 178 Posts
Regarding Carbs and chokes----All 1967-69 Camaro with Holley carbs had automatic chokes that are controlled by a thermostatic coil located either on the intake manifold or on the exhaust manifold ---THe EXCEPTION to this is the ZL-1 which had no choke----The early ZL-1 cars were produced with Holley 4346 and were later retrofitted at Gibbs with the 4296 carbs. The 4346 is the correct carb for 1969 396/375 & 427/435 engines---the Chevy part number and ID number for a 4346 carb is 3959164--- the Chevy part number & ID number for a 4296 carb is 3955205---my 2 cents
As far as spoilers go I ran a 1967 in Modified Production F/MP with ONLY the front spoiler never was questioned about not having a rear spoiler that car would always high MPH and it would out MPH by 1 1/2 to 2 MPH using the same exact engine in a 64 Corvette with the same driver . Coincidence perhaps? But I thought it looked kinda cool anyway---sold the car with the spoiler on it and the new buyer left it on last I ever saw it. FED 387 Last edited by FED 387; 04-01-2023 at 11:48 PM. Reason: correction |
#20 | |
Liked 880 Times in 311 Posts
Reminds me of some long conversations you and I have had about rules & racing in general. Our friend also says there is no Gray between the black and white lines of the rule book. But You and I know different. lol I think there are a couple of Dwight rules in the book as well as a couple of Adger rules. I bet we could come up with a pretty good list of "Named Rules" Might even be considered it a list of Who's Who in class Racing.
Adger Smith (Former SS) Last edited by Adger Smith; 04-07-2023 at 06:33 AM. Reason: sp |
