Old 04-01-2023, 05:04 PM   #1
DRAKE VISCOME
Liked 92 Times in 36 Posts
Default rear end gear set availability 8.8 Ford
Beyond 5.13 ring & pinion (ratio)...for 8.8" Ford rear...anything available between the 5.13 & next ratio we are aware of 5.71 ???...much thanx...for any/all help... Drake
DRAKE VISCOME is offline   Reply With Quote
Old 04-01-2023, 08:17 PM   #2
Robin Lawrence
Sponsor
Liked 716 Times in 120 Posts
Default Re: rear end gear set availability 8.8 Ford
Nope, I tested an 8.8 Drop out center section and we also tried to find ratios near my current 5.43. Nothing is available between those ratios in an 8.8.
I ended up testing the 5.13 and will test the 5.71 at some point.
Robin
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
Old 04-01-2023, 11:57 PM   #3
DRAKE VISCOME
Robin
Thanx Robin...ideally think something 5.43/5.57 would be a-ok...the 5.71 a bit too much without getting into tire height changes...thought awhile ago was told there was a 5.57 gear set for Explorer 8.8...so guess we'll stay @ 5.13 for present --Drake
Old 04-02-2023, 09:19 AM   #4
BRETV
Liked 776 Times in 199 Posts
Robin
8.8 drop out center section? There's a 12 bolt drop out center section, never heard of an 8.8 one. Who makes it?
Bret Velde
2003 ??/SA
BRETV is offline   Reply With Quote
Old 04-02-2023, 10:10 AM   #5
DRAKE VISCOME
Robin
thanx yet again Robin...
Old 04-02-2023, 11:49 AM   #6
Ralph A Powell
Liked 226 Times in 137 Posts
You are correct the Strange drop used Chevy 12 gears but the pig went into a Ford 9” axle housing. As I remember it was done at Ford’s request to run in NASCAR resistor plate races! NASCAR said NO YOU CANT RUN THAT.
Bret Velde
2003 ??/SA
Old 04-02-2023, 12:49 PM   #7
Robin Lawrence
Sponsor
Bret Velde
2003 ??/SA
I am sorry I can't say just yet. These were development pieces that I was asked to test. As soon as I am allowed, I will pass along the status of the program.
Robin
STK 308
SS 3088
Old 04-02-2023, 12:53 PM   #8
BRETV
Robin
Keep me posted Robin. Thanks! I also sent your info to a friend of mine to dyno his GT500.
Bret Velde
2003 ??/SA
Old 04-03-2023, 05:23 PM   #9
ron kievit
ron kievit's Avatar
Liked 20 Times in 4 Posts
yukon had 6.14 gears i used when I ran w/s 88 mustang 2300 4 cyl. around 1999
ron kievit is offline   Reply With Quote
Old 04-04-2023, 12:16 PM   #10
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
Bret Velde
2003 ??/SA
I remember Strange having one years ago, same time they came out with the 12 bolt one. Now there is this Chassisworks one.
Name:	8-8 chassisworks.png
K Danner STK 468
kdanner is offline   Reply With Quote
