Old 02-10-2023, 04:20 PM   #1
Gregg Luneack
Liked 225 Times in 30 Posts
Default Misc Parts
1- Powerglide,1.96 ratio, trans brake, roller tail housing
new yoke for 1350 joint,no runs since freshen up. $1250.00
1 -used B&M PRO Stick with cable. $180.00
9- New Venolia Pistons,327 superstock, 4.061dia.
.031x3/16 ring groove,.875x2.500 pins included. $750.00
8 - New Eagle H-beam rods, CRS6250b3d, 6.250long
2.225 big end, .927 pin end. $ 300.00
1- used Moroso Aluminum SBC Superstock pan,12" wide
rear sump 8" deep, kick out . $550.00
New 875.2.250 Pins $90.00set
New .875x2.250 Pins $90.00 set
New MSD # 85551 Chevy Distributor $275.00
New MSD #6425 Digital AL-6 ignition $250.00
1-set Performace Welding Merge collectors, 2 1/8 2.5 choke
3' exit,14' in long,o-2 bungs, powder coated $ 275.00
2- 041 bare heads $200.00
8-New SBC Lunati roller rockers, 1.6 ratio, 7/16 stud, $125.00
1-pair #840 rectangle port BBC heads, no grinding,bare, $800.00
1-67 Camaro steering wheel, black ,nice $275.00
you pay shipping, 760-630-9094
Gregg Luneack is offline   Reply With Quote
Old 02-10-2023, 09:45 PM   #2
Jeff Stout
Liked 708 Times in 285 Posts
Default Re: Misc Parts
Greg what model or name for the 8 Lunati rockers? Voodoos?
Old 02-11-2023, 01:36 PM   #3
Gregg Luneack
Jeff, these are 25 plus years old,the color is red,
before they called them a fancy name. made in USA.
Old 02-11-2023, 01:41 PM   #4
Jeff Stout
PM sent
Old 02-12-2023, 09:01 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
1.96 PG
is that the lt weight 6 cyl carrier or the 1.76 V-8 style carrier?
Helical or St. cut teeth
T-brake?
Adger Smith (Former SS)
Old 02-13-2023, 07:30 PM   #6
Gregg Luneack
Originally Posted by Adger Smith View Post
1.96 PG
T-brake?
Has trans brake,with New ATI solenoid,
1.76 large planetary,I think helical gears?
Old 02-25-2023, 10:21 AM   #7
70Z28350
Greg, would you ship trans?
70Z28350 is offline   Reply With Quote
Old 02-26-2023, 09:10 PM   #8
Gregg Luneack
Yes, I would ship at your expense!
