Old 02-03-2023, 10:09 AM   #1
Ok stocker
Liked 100 Times in 24 Posts
Default Lowering front end 96 Camaro
I need to lower the front end. It’s a P/sa car so light front end. What is the best option to get the front end where it needs to go?
I am new at this so go easy on me.
Ok stocker is offline   Reply With Quote
Old 02-03-2023, 11:44 AM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Lowering front end 96 Camaro
Aftermarket springs and shocks with threaded body is the easiest way to adjust ride height.
Old 02-03-2023, 12:51 PM   #3
jamie2370
Liked 239 Times in 90 Posts
If that were legal in stock eliminator lol, 96 camaro has struts so there is NO legal way to do that. Best way is to get a front end weight and call Santuff. They will give you the best shot of correct height with correct weight transfer on the 1st try.
jamie2370 is offline   Reply With Quote
Old 02-03-2023, 12:53 PM   #4
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Lowering front end 96 Camaro
Good morning to all,
A coil spring change might be enough to correctly lower the car. Be aware that if a drastic amount needs to done to get the proper ride height an alignment will also be necessary. Have the toe in / toe out checked, and camber change and bump steer investigated as well. If you have access to a good front end specialist, I would also consult with one of them.
Good luck with your endeavors, and stay "Straight"!
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 02-03-2023, 06:35 PM   #5
Rob Petrie E395
Can you post a picture of what is legal on a 4th gen F body? Because apparently my car is illegal.
Old 02-03-2023, 09:15 PM   #6
Mark Lewis
Liked 210 Times in 47 Posts
those camaro's have a coil over type shock. You can go with the afco shock or get some from Randy Mans. With the V6 I would start with a 125 # spring. Happen to have some if you go that route. They were too light for the LT1
Mark Lewis is offline   Reply With Quote
Old 02-04-2023, 10:13 AM   #7
Ok stocker
I would be interested in the springs. The 125 is what I was thinking.
Old 02-07-2023, 04:43 PM   #8
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
I think you’re confusing an 82-92 Camaro Firebird with a front strut, to a 93 to 02 which comes with a factory Coilover shock. It is indeed legal to use that shock.
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 02-07-2023, 05:28 PM   #9
jamie2370
LOL...I read 92 not 96. Sucks getting old
Old 02-07-2023, 08:49 PM   #10
DCox
Liked 4 Times in 2 Posts
Front coil over shocks
Call Marty Rinehart at Rinehart Performance (717) 880-6716
DCox is offline   Reply With Quote
