#21 |
Liked 705 Times in 204 Posts
No, no and no!
I left super gas racing to get away from delay boxes and throttle stops slowing everyone down to 9.90. Pro Tree and Instant Green would be a mess using handicap starts. At least in the .90 category the cars leave together on the tree. I hated sitting against the converter when we had a slow tree. From the drivers seat waiting for a little over a second seems like an eternity. Imagine running your A or B stock car against a 14 or 15 second car, what are you going to do sit against the converter that long or try to anticipate the difference? The fans in the stands aren’t going to like it either. I like watching the countdown from the stands it gives you the perspective of the difference between the cars, something that you will lose with a pro tree style handicap start.
Mike 7570 A/SA |
#22 |
Liked 68 Times in 41 Posts
There is no yellow lights. You stage your car and the next light you see is green
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
#23 |
Liked 22 Times in 14 Posts
Seattle in the early eighties was .5 pro light with no deep staging but you had to roll in some.The best I could cut with a 12 second car averaged about .620. You need to have the front end tight with no lift, the car has to go straight ahead immediately. Most cars will wind up with as small a front tires as possible, 13 " is legal, they'll be there. The lightest cars will dominate some combinations will become extinct when in comes to dial in racing and forget about stick shifts, there's a reason there are virtually none in .90 classes.But for heads up runs where both cars are similiar and no dial ins it might be O.K.
#24 |
Liked 10,931 Times in 2,258 Posts
What is the opposite of a delay box, ‘cause that’s what I will need.
#25 |
Cattle prod?
#26 |
Liked 561 Times in 138 Posts
How many pages is it at? Ha!
Tim Stickles |
#27 | |
Liked 1,112 Times in 304 Posts
#28 |
Liked 351 Times in 76 Posts
What exactly is this instant green supposed to accomplish, If your blocking it's instant yellow now. Just pick a bulb and leave on it ?
Dale Hulquist 4006 Stk 4006 S/Stk |
#29 |
Maybe we can get the guy from Pinks all out to do arm drops for stock and super stock!
Tim Stickles |
#30 |
Liked 328 Times in 80 Posts
I could see an experienced blinder driver, that is already tough, being just as tough at night now. There would be no amber light bleed over. The guys not doing this would be even further behind, ie. the learning curve to get your car moving as quick as possible. I agree, that the lighter cars will have an advantage as well.
Ernie Neal SS 354 PS; I kinda liked the idea at first until I thought about the outcome |
