#41 |
Liked 282 Times in 103 Posts
There clearly are a lot of combinations that need horsepower added,but I've always thought that somehow they need to take weather conditions into it.Might be hard to hook up,but I saw on Facebook that the air in Bowling Green right now is - 4200 ft.
I don't think it would be right to penalize a lot of the combinations when the air is that good. But over a second under in Bristol might be worthy of some horsepower. The mineshaft rule never took into account the weather. Ironically, it only came into play when the weather was the worst like Indy. |
#42 | |
Liked 574 Times in 137 Posts
Maybe it doesn't matter because the mineshaft rule is dead but certainly another wrinkle/question mark/downfall/limitation/problem with the AHFS. |
#43 |
Liked 317 Times in 103 Posts
I usually ran about -.45, without lifting or staying in it. I do not have a problem with the new system. If you are that fast (-1.20 or whatever)), you probably need HP. NHRA did not do any favors with their new system. Raising or lowering the indexes does not work, just moves numbers around. NHRA's factoring of cars is an absolute joke, so many adjustments that are so far off. The enhancements given to combinations just adds to the confusion. Racers complaining, just like it was 50 years ago. Same response from 50 years ago, "work on your stuff". Work on your stuff means writing for mercy to NHRA. Did you ever think of all the combinations that were absolute jokes before they were adjusted. This circus never stops, it will be like this ten years from now too. And you know what you are going to do? Just like always, OK.
Cut a light, hit the number, if it's heads up, good luck, go work on your stuff. I have memories of Mike Senia's Cimmaron, Bob Dennis "banana car" Olds, Bob Shaw's cars, McKay's Buick, and a herd of 302 Fords. Ron Ortiz U/SA nitrous 4 sale.
Ron Ortiz 2102 STK |
#44 |
Guest
Posts: n/a
In reality- what’s the difference?
You ask for HP reduction or you ask parts or you do both. A few continue building HP and either way it is accepted. Still wondering what has swayed NHRA in this direction. Out of the Big Three , who has the most reductions? Merry Christmas! |
#45 |
Liked 1,471 Times in 308 Posts
Barry, what has swayed NHRA in this direction? The constant reference
to the fact that the present AHFS is a failure and they decided to try and do something about. If everybody runs all out it works, just like the old system. Nobody wants HP, so if you think what we did before was sandbagging, wait till you get a load of this year. Why will we do this? Because everybody wants an advantage. This is racing, we want to win more than the next guy, qualify better than the next guy, make the best run in our class in the Nation, bury the record with some serious MPH to show off our HP, and we don't want to give anything back, we want to repeat great runs all of the time. Is this the answer, probably not, but shortening up the window to -65 to -85 under, AND taking away mineshaft, there will be a large amount of HP added to combo's at adjustment time. It is not a favourite with many, but it looks like all we got. Association Races look better all the time. J.R. |
#46 |
Liked 1,955 Times in 590 Posts
I agree there should be mineshaft exclusions from the AHFS. It should be triggered by weather conditions and not the qualifying order. High barometer at or above 30.20 and below seal level conditions. Any runs during that threshold do not count. Just make sense.
Mike Pearson 2485 SS |
#47 |
Liked 2,752 Times in 973 Posts
James,
I don't use drugs so I'm not high. I'm well informed but apparently not as well as you. Merry Christmas! Frank |
#48 | |
Liked 2,343 Times in 465 Posts
#49 |
Billy aren't you the one that's been on here for years saying that the 396/375 combo is built with all aftermarket parts. With all the parts you talk about there so good you don't have to do anywhere near the amount of work on them that you need to do with the stock factory parts to get them to run that fast. BP
#50 |
It's about time that you woke up Barry! Probably dreaming about what NHRA is going to give you next.
Merry Christmas and a Happy and Healthy New Year! See you in the spring!
