Old 10-27-2022, 06:05 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default 427/450 LSX Engine - Jesel - Misc
427/450 Stock eliminator LSX engine - Class winner in 2018 and 2019
Block lightened 28 lbs
Custom cam tunnel
GP Technologies ported aluminum cylinder heads
Victory valves
PSI valve springs
Jesel 1.9 Aluminum rocker arms
Trend custom pushrods – polished tips
Jesel custom bronze lifter bushings
Stefs performance aluminum fabricated oil pan
Scheuman racing custom oil pump cutdown G-rotor gearset with custom pickup
ARP cylinder head studs
ARP main studs
Carillo connecting rods
Callies crankshaft – 4” stroke
Diamond custom pistons
Total seal custom ring package
ATI performance balancer with custom hub – heavy inertia weight and heavier durometer rubber
Custom designed Cam motion hydraulic roller camshaft
Jesel roller lifters
GM seamless roller timing chain
CFE custom intake
Accufab throttle body
FAST 65lb @ 58psi injectors
Meziere Billet Water pump
As tested on 4/25/18
880hp at 7900 RPM
633 lbs ft of torque at 6500 RPM
$42,500.00
2 – Lingenfelter billet steel LS block girdles, No hardware – girdles only $500
2 GM truck oil pans (1999-2006) pan only $50.00 each
Jesel KDR-57100 lifter retainer set set of 8 –400.00
Jesel PLT-53233 – 475.00 new – set of 8 – 225.00
Jesel Dogbone lifters LFD-44002 – set of 16 – 2500.00
Jesel sportsman rocker arms set with stands - 1.9 ratio for LS DR heads set 800.00
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
