Old 10-01-2022, 01:35 PM   #1
Liked 5,155 Times in 1,968 Posts
Default New Question of the Day
I just read the rule book down load about automatic shifting in Stockers .
I couldn't c&p it from there, but it says that electric upshift can be used in the vehicle was originally equipped with a computer.
Are they talking about engine management computers or about auto transmissions originally being controlled by the computer? Or maybe delay wiper or electronic cruise control computers?
Reason I ask is because the factory /experimental cars came with T400's and PG's, which were shifted by a governor originally.
Old 10-01-2022, 06:19 PM   #2
Keith 944
Keith 944's Avatar
Liked 1,887 Times in 579 Posts
Default Re: New Question of the Day
That’s funny, but a very good point
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 10-02-2022, 10:29 AM   #3
SSDiv6
Factory Stock cars running the TH-400, Powerglide, or C-4 are not computer controlled.
I believe this applies to the other EFI cars that have computer-controlled transmissions.
Old 10-02-2022, 12:03 PM   #4
It looks like 1997 and newer GM RWD cars would be the first ones to be able to use electronically controlled upshifts.
Anything earlier , the lock up converter function only, could be employed
Is that correct?
Enter the 4L60 and 4L60E
GM renamed the TH700R4 in 1990 as the 4L60 to reflect its purpose as a four-speed with a longitudinally placed matching engine and a gross vehicle weight rating of up to 6,000 lbs. The automaker made no mechanical changes to the TH700R4. In 1997, the electronically controlled-shift version became available in rear-wheel-drive cars and two- and four-wheel drive trucks. The sixth-generation Chevrolet Corvette was also equipped with the 4L60E transmission. The 4L60E used solenoids and electronic actuators to control the clutches, valve body and bands to shift gears. GM's Vehicle Speed Sensor and a vehicle powertrain computer determined when gear shifting was optimum. T
Old 10-02-2022, 12:07 PM   #5
Billy Nees
Liked 7,923 Times in 1,759 Posts
I've been told that certain FFFords had electronic trans in '94?
Billy Nees 1188 STK, SS
Old 10-02-2022, 12:10 PM   #6
I guess it depends on where you look ..No wonder NHRA is confused on this subject.
GM upgraded the 4L60 to electronic control with the 1993 model year and these transmissions were used in a wide variety of applications from the Camaro and Corvette to full size cars and light and medium duty trucks. The big improvement was total electronic control which eliminates the need for the troublesome TV cable and also did away with the spinning weights and springs used in the governor, since input and output speeds are now measured by sensors and the up and down-shifts are controlled by an electronic transmission controller.
FWD
GM started adding electronic controls to the 4T60 in 1990 with the Cadillac Allante carline's unique F7, and 1991 and after with the corporate 4T60-E.
Old 10-02-2022, 05:11 PM   #7
GTX JOHN
I have not seen them police the 1 -2 shift for years.
I would not worry about it in any Stocker!
John Irving
741 Stock
741 Super Stock
Old 10-02-2022, 05:21 PM   #8
GTX JOHN
John Irving
741 Stock
741 Super Stock
Old 10-02-2022, 05:28 PM   #9
Billy Nees
That's done with the governor not an electronic shift.
Old 10-03-2022, 02:23 AM   #10
GTX JOHN
No sir = At least not on many transmissions I have seen....
But I better not Elaborate on this site.
I can explain to you privately.
John Irving
741 Stock
741 Super Stock
