Old 09-03-2022, 01:41 PM   #1
randy hopkins
Default Built by Ford N/A 5.0 mod Stocker Motor (1 of 7)
I of 7 Cobra Jet 5.0 race motors hand built by Ford. Motor is totally unique, special block, rods, oil pan, 12 to 1 pistons, C&C heads, special cams, intake manifold is 1 of 7 proto types that you cannot buy without buying 1 of these motors. SCJ throttle body. These motors are extremely fast in NHRA stock eliminator. Motor is new in crate, dyno tested only by Ford.
I have identical motor that has been raced as a Cobra Jet stocker, ran 9.80's @ 135 MPH, making over 600 HP. Probably has 25 runs on it.
Will sell separately or both motors in a pkg deal.
ID:	64574   Click image for larger version
randy hopkins is offline   Reply With Quote
Old 09-03-2022, 06:30 PM   #2
bubski
Liked 165 Times in 60 Posts
Default Re: Built by Ford N/A 5.0 mod Stocker Motor (1 of 7)
Bubski would never try to derail your post or sale !! But has to ask ?? How does a1 of 7 engine combo fit in stock eliminator?? Maybe 390 AMX’s should be allowed in say F stock to start with !! Cheers !! Sorry about the negative response!! But Bubski’s just curious! Good luck on your sale !!
bubski is offline   Reply With Quote
Old 09-03-2022, 06:59 PM   #3
SSDiv6
What Randy is implying is that the engines, 1 thru 7, were handbuilt from selected parts. The 5.0 N/A Coyote engines are in the books, including the part numbers.
Old 09-09-2022, 01:50 PM   #4
ProfessorRock
ProfessorRock's Avatar
Liked 48 Times in 24 Posts
Randy Pm me about the engines
Pls
ProfessorRock is offline   Reply With Quote
