Old 08-14-2022, 08:41 AM   #641
Liked 10,678 Times in 2,221 Posts
Default Re: Dumbo The Flying Elephant
Getting closer to smelling smoke. Front cover, water pump, damper installed and torqued. Holding the block with one hand a pulling the damper bolt to
129 Ft/lbs it took a few try's but I got it done. Checked TDC to the ATI damper it was spot on. Today is head day. The heads are easy. Its the pushrods and valve train that is more fun than an empty barrel.
Old 08-14-2022, 11:33 AM   #642
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
thanks for this build thread, Larry. As a daily auto repair shop owner/ worker and former racer I enjoy every word about the precision you are going through. Can't wait to see the results!
Old 08-15-2022, 03:11 PM   #643
Started to put the last head on then I realized the lifters will only go in before the head is installed. It's just one more stupid old man trick.
ID:	64224   Click image for larger version
Old 08-16-2022, 01:59 PM   #644
No place for big hands and fingers, its busy up there.
Old 08-17-2022, 07:27 AM   #645
I got to make a tool that I can hang on a rockerarm and quickly check piston to valve clearance at split overlap. How I did it yesterday was slower than molasses on a real cold day in Nova Scotia. Got it done. It was interesting to see how the piston speed and the valve speed stayed in the same clearance for a number of crank degrees. There has to be some real smart folks doing this, me I just have to follow directions.
Old 08-17-2022, 05:46 PM   #646
Dumbo is starting to develop a little bit of a personality. I still need to button up the oil pan, but that will be tomorrow.
Today is Taco Tuesday a day late but the margaritas will be good. They won't be as good as Stan and Shella's but they will contain "grog" and imitation lime juice and salt. I know they will be bad for my diet, but oh well!
ID:	64227   Click image for larger version
Old 08-18-2022, 05:41 PM   #647
Ta-Dah
I just hope its not Ta-Dud!
I hope to record a Dyno pull or two next week, good or bad. As Steve Kopein would say " I just got's to know "
I know I'm not finished but there is a list of things I want to try on the next one. Patsy says I'm hopeless.
Old 08-20-2022, 07:13 AM   #648
Getting ready to go to the dyno I feel a little like Santa Clause. You know making a list and checking it twice to keep from forgetting something that is needed to be a successful trip. It took me at least 15 minutes to come up a list of items I think I need. A lot of spare this and spare that plus gas, oil, ICU, and computer.
I forgot I was low on fuel and meeting my file guy this morning at 8:30 am.
The worst thing about this weekend is we are missing the Danny Coffman Memorial Race at Bowling Green.
Old 08-20-2022, 12:45 PM   #649
Frank B.
Liked 43 Times in 24 Posts
Where are you dynoing?
Frank B. is offline   Reply With Quote
Old 08-21-2022, 08:24 AM   #650
Frank Castros
Liked 2,626 Times in 950 Posts
Larry usually goes to Jeff Taylor's shop.
