Old 06-08-2022, 08:41 PM   #1
qflash
Default 307 Olds L/SA converter
What converter manufacturer makes the best converter for a Metric 200 behind a small cube engine, 307 Olds.
I have a Turbo Action, won't stall up on the line above 2600. I have a PTC, won't stall on the line above 2500. Need to put it on the 2-step at 3000-3200.
Any help is appreciated.
Ron Miller Div 4, 4307
qflash is offline   Reply With Quote
Old 06-08-2022, 08:57 PM   #2
GTX JOHN
Default Re: 307 Olds L/SA converter
I run an ATI 8 inch in my 318 N/sa and O/sa wagon
It will sit comfortably @ 3800 on two step when required.
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
Old 06-09-2022, 08:52 AM   #3
nhramnl
Liked 358 Times in 83 Posts
Cool Re: 307 Olds L/SA converter
So John Irving is suggesting that if your converter won't convert, convert to a different converter...
Old 06-09-2022, 09:16 AM   #4
dragracerray
dragracerray's Avatar
Liked 210 Times in 91 Posts
Ron how did you communicate your engine horsepower to TA and PTC? Did you send them a dyno sheet? If you didn't then these companies think you are making more torque than you are. In my experience converter companies are pretty good and meeting your requirements on the first try. After you have real data from using the converter in the car they are really good at meeting your requirements on the second try. I would ask either of these companies to tune one of the converters you already have. Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 06-09-2022, 10:09 AM   #5
garyc
Liked 51 Times in 30 Posts
just purchased a new custom 8" converter from T/A for my L/SA mopar 400, first stall adjustment is free, was your converter made for your car?? need stall adjustment?
garyc is offline   Reply With Quote
Old 06-09-2022, 06:31 PM   #6
qflash
GTX John; Who do I talk to at ATI?
Old 06-09-2022, 08:53 PM   #7
GTX JOHN
Sorry = My contact is no longer there!
John Irving
741 Stock
741 Super Stock
Old 06-10-2022, 06:58 AM   #8
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Charlie Plott if he didn't fully retire.
Old 06-10-2022, 12:04 PM   #9
Greg Marshall
Greg Marshall's Avatar
Liked 10 Times in 6 Posts
Hi Ron deal with Charlie Plott at ATI. I have 2 convertors from them original one and one they built in march 22. 1.48 60’ft behind the 307 you can hold it at 3300 on the starting line. Cplott@atiracing.com
Greg Marshall is offline   Reply With Quote
