Old 04-14-2008, 01:18 PM   #31
neb5445
Default Re: 69 z-28 camaro ?
If the 1970 had a copo option with a 454 ls 6, why doesn't NHRA have those available to race?
neb5445 is offline   Reply With Quote
Old 04-14-2008, 05:06 PM   #32
Chevy454
No 454 in a Camaro *ever*...396/375hp was the largest in 1970...and the only performance COPO found on a '70 Camaro is COPO 9796, which was the tall rear spoiler for the early built '70 Z cars.
Interestingly though, my original Tech Guide does indeed have a listing for a 1970 454/450 (LS6) Camaro, as well as a 1970 454/465 (LS7) Corvette (found in my original Classification Guide also!)...these would have been 2 pretty deadly street combos, too bad they never materialized!
69 Pure/Stock Yenko Camaro 11.73 @ 118
Chevy454 is offline   Reply With Quote
Old 04-14-2008, 05:39 PM   #33
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
I have a 1970 Chevrolet dealer brochure that shows a 454 460hp engine option for a Corvette. Of course we know why that is not in the class guide
Old 04-15-2008, 08:38 AM   #34
neb5445
I see it was offered in a Motion Camaro from New York.
Old 04-15-2008, 10:56 AM   #35
Jeff Lee
Jeff Lee's Avatar
And you could get a Motion Camaro with an LS7 and a tunnel ram. But that doesn't mean it's acceptable to NHRA...
Jeff Lee 7494 D/S '70 AMX
Old 04-15-2008, 11:29 AM   #36
Robert Bullard
seems all Z 28s had be a X33 or a X77. this is on the trim tag on the fire wall at the master cyl. lots of so called Z 28s are not really Z 28s.
Robert Bullard is offline   Reply With Quote
Old 04-15-2008, 12:18 PM   #37
Chuck Norton
Liked 89 Times in 19 Posts
A '69 Camaro built at any point in the model run at the Van Nuys plant (would have a "L" in the vin#) was not assigned an X-code, no matter how it was equipped. Also, Ohio-built 1969 Camaros (an "N" in the vin#) that were produced prior to December, 1968, do not have any X-codes.
Chuck Norton is offline   Reply With Quote
Old 04-15-2008, 04:28 PM   #38
Casey Miles
Liked 508 Times in 92 Posts
Smile Re: 69 z-28 camaro ?
I have an original Z/28 from Baldwin Chrevolet. It came with no console, no power steering and the fuel guage is where the clock is in the standard model. I still have the original window sticker and wanrantee charge card. The car came with a cowl hood and I beleive it was a part of the Z/28 package. It might even be a separate line order on the window sticker. Jerry Mcneish, I'm sure could answer questions about Z/28's
Casey Miles
248H
Old 04-15-2008, 08:50 PM   #39
John Leichtamer Jr
John Leichtamer Jr's Avatar
Didn't all cowl hood option car come with the hood, rear spoiler, and airdam under the front lower valance.It seems that alot of the cars running in stock & super/stock only run the hood and not the rest of the option. Whats with that??
Hammer
John Leichtamer Jr is offline   Reply With Quote
Old 04-16-2008, 08:41 AM   #40
Casey Miles
John: Back in the day, NHRA forced you to have the spoiler and the air dam or neither of them. You couldn't mix and match. Now NHRA doesn't seem to care or they don't have the experience of what should be correct for the 69 Camaro's. The air dam speeds you up and the spoiler slows you down, so that's why you see the cars with air dam only. NHRA should reenforce the rules on which way the cars are configured. Also, that option wasn't offered on all 69 Camaro's, depended on what engine was installed and model the car was if you could get the air dam and spoiler. The true cars offered with the air dam has a threaded bolt hole in the H frame for the air dam center support.
Casey Miles
248H
