Old 04-28-2022, 10:49 AM   #1
qflash
Default Solid lifters on a hydraulic cam
I have installed a new Bullet hydraulic cam and solid lifters in my stocker and broke it in properly.
Now I need to set the valves for racing. What valve lash for valves set cold as opposed to hot?
Thanks, Ron
qflash is offline   Reply With Quote
Old 04-28-2022, 12:08 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 986 Times in 314 Posts
Default Re: Solid lifters on a hydraulic cam
Thanks, Ron
Depends whether you have aluminum or iron heads. Best method is set them cold then see what it changes to when hot.
Old 04-28-2022, 12:54 PM   #3
qflash
Iron heads on an iron block.
Old 04-28-2022, 04:19 PM   #4
65signet
Liked 49 Times in 22 Posts
You can set them really tight, from 3 to 5 thousand's
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 04-29-2022, 08:50 AM   #5
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Solid lifters on a hydraulic cam
Thanks, Ron
Good morning Ron,
You could consult with Bullet on this since they ground the cam, I'm thinking they would best. I'd also set the lash a couple of thousand's looser on the exhaust side verses the intake side due to the extra heat in that valve over the intake valve. You'll find everything will expand or contract due to temperature difference's. Have a productive day!
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
