Guest
Posts: n/a
Has anyone heard that NHRA has approved the use of aluminum heads (The Edelbrock Heads) for the replacement of the CI ones that can be no longer Located? it was said they still had to have the same spec's as the CI ones. (IE; 2.06/1.72 valves, the same cc's and the same intake/exhaust spec's)
Liked 237 Times in 126 Posts
There are two new Edelbrock heads on the current list (3/27/14). They are numbers 60547 and 60447. Does this help?
Dale
Liked 285 Times in 87 Posts
The Edelbrock 60547 has a 315 runner and is the same as the GMPP "401" head both being Rectangle Port and Legal. The Edelbrock 60447 has a 290 Oval Port runner, but is listed from suppliers (Summit & Jegs) as NHRA Legal and is described as having 2.19 - 1.88 valve seats. Obviously there is more to this, than I would be ready to assume. Could make quite a difference on a 325-350-360HP combination if its reality. MB.
Liked 128 Times in 50 Posts
Isn't this for Super Stock only though?
Bobby Lundholm 3516 G/SA |
per Edelbrock's website, the rectangle port is legal stock and ss, the oval port is super stock only.
Chad Rhodes 2113 I/SA |
60447 is for the 396/325/350 HP combo's for SS only. Too bad thought I was getting some aluminum heads.
The 60547 heads on summitracing.com says the spark plug hole is moved closer to the combustion chamber by .150 and the NHRA rule book says it has to be in the same location. Not sure how it's an accepted product
Liked 30 Times in 17 Posts
#9 | |
Liked 232 Times in 108 Posts
#10 | |
Liked 7,907 Times in 1,754 Posts
Somehow, I just don't feel sorry for the poor Stocker guys that run a 396!
