Old 02-09-2022, 09:19 PM   #111
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Angry Re: Access to AMA Shipping Weights?
Sure wish we would have waited to enter no- problem. Now we're entered with a combo that no longer exists 1983 Camaro 305 200/263. Getting harder and harder to keep this up.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 02-09-2022, 09:21 PM   #112
SS/GSI
SS/GSI's Avatar
Liked 759 Times in 109 Posts
Default Re: Access to AMA Shipping Weights?
I formally requested NHRA to look into the 1993-2002 Firebird Shipping Weight last winter. This shipping weight fiasco was created from the "body in white" program Pontiac had in the 90's and also while they were a major sponsor of NHRA.
I first asked for the 1998 Firebird to be reviewed, provided all MVMA Federal documentation, contact names and all sources to NHRA. I informed NHRA that once the '98 was reviewed, I would then be seeking reviews of all the 1993-2002 Firebird Shipping Weights.
NOTE: The reviewing of the entire MVMA shipping weights for the stock classification guide across all manufacturers was the sole decision of NHRA. NOT MINE
For decades everyone has known, mentioned and complained about the obviously doctored/distorted/favorable Shipping Weights in the guide, as they pertain to the 1993-2002 Firebirds. Between those years, the Firebirds are anywhere from 150-300#'s lighter than an identical Chevrolet Camaro, depending on the model, thus allowing them to run classes their "sister" car could not!
When NHRA and I began our correspondence, I believe there was skepticism from some people that the Stock Classification Guide could be this "off"; however once I began sending them the MVMA Documents, they became more receptive and understanding of my frustration with the guide.
In NHRA's defense, a majority of MVMA "sheets" over all the years were given to them by the performance departments from most manufacturers and obviously those manufacturers probably wanted their cars in favorable classes and or in the "faster" classes, therefore the discrepancy in many shipping weights. This information also wasn't available via the internet back then and was not disclosed publicly, due to the Information Act until lately. You have to remember that technology, computing and the transferring of information has come leaps and bounds over the last two decades.
I was also informed that NHRA was going to first roll out a statement mid January this year, probably on NHRA Racer.com, and it would detail that the shipping weights were being reviewed and updated for the entire guide, where documentation was available to do so. The new weights would only take affect January 1, 2023 and that once posted that all competitors would have a protest period of sorts(90-120days) to seek more clarification, explanations and/or contest the changes via discovery of new information, they themselves could provide to NHRA...Obviously as we all now know, that is not at all how it unraveled!!!
I do not apologize for requesting NHRA to look into my request. If you were affected, perhaps you should do some research and ensure that NHRA has made the right calculations...as Mr. Hill mentioned, people make mistakes. If you received a favorable shipping weight, I would also suggest making sure it is legit, seeing as your new and/or ex class competitors will want to make sure yours is correct as well.
NOW, HERE IS MY HUGE F@#KING PROBLEM!!!
Of all the cars that the shipping weights were changed on, and all the competitors which were affected...can you guess which one(s) were NOT???
The ONLY Shipping Weight untouched in this whole f#$king fiasco was the ONE car I asked to review in the 1st place!!! The 1998 Pontiac Firebird LT1 c/w Ram Air Hood(3050#/3011# SW). Also the 1995-1997 Firebird FireHawk LT1 c/w Ram Air Hood.
When I asked NHRA why they would not touch this car that;
A. Never Existed(1998 LT1)
B. Manufacturer No Longer Exists
C. A hood is making an almost 300# difference in SW
They responded that its a "paper" car, that their has been a 20+ year precedence for its shipping weight and they would not want a lawsuit to form over implementing a new and more realistic shipping weight on it!!! So what about the precedence for the 30+, 40+ and 50+ year old combos???
But then why did the 1995-1997 Firebird Firehawk remain 3050#'s...I have those MVMA Documents Directly from the Pontiac/GM Archives and that car weighs North of 3250#'s for all 3 years in question?!?!
I also gave NHRA the MVMA documents as it pertains to the LT1 vs LS1 engine weight. The LT1 weighs 88#'s MORE THAN the LS1(steel block LT1 vs aluminum block LS1 +++). Therefore it would only make sense for the LT1 ALLOWED ENGINE Combination in a 1998 Firebirds to run 88#'s heavier shipping weights than the LS1's, NO???!!!
So, NHRA changes the entire Stock Classification Guide but leaves out the car requested for review...sounds about right!!!
So, if you are a 1993 to 2002 F body competitor, and you are OK with one make, model, platform car getting a 300# +/- advantage on you, then I guess I will have to be OK with it...IF you are OK with adding 300-400#'s to your ride while fully well knowing that there are documents and simple mathematics out their to make the Firebirds, detailed above, not have to do it as well, because of some unknown bias and/or legal threat, than I guess I will have to be OK with it too.
Don't bother or waste your $$$ to threaten to sue NHRA over all of this. All they will do is get rid of all shipping weights in STK & SS, like they have in GT/Modified and then its case closed.
...or maybe that is what NHRA hope comes of all of this??? One less thing to do!
SIDE NOTE: The 2015 Camaro 376ci(which runs A, B and C/SA)MVMA Shipping Weights is 3946#'s NOT 3320#'s!!!
Kevin Gaffney
1123 SS/GA
SS/GSI is offline   Reply With Quote
Old 02-09-2022, 10:00 PM   #113
GTS340
Liked 1,364 Times in 417 Posts
Any bets this all goes away.
Paul
Old 02-09-2022, 10:02 PM   #114
Doug Hoven
Liked 870 Times in 165 Posts
Not sure if this story is 100% true, but I was told that in 1998, GM racing had not fully developed the ls1 as part of their program. Pontiac racing opted to stick with the lt1 for the 1998 model year for their race cars. They never made any body in white “race only” Camaros, so they, along with all of the street trim cars, came with ls1 engines.
1189 F/SA
Defunzalo Racing Enterprises
Old 02-09-2022, 10:14 PM   #115
MANSRACING
Liked 10 Times in 4 Posts
This should have never even started in the first place.Just keep it up and there won’t be any Stock/ SuperStock.
Randy
MANSRACING is offline   Reply With Quote
Old 02-09-2022, 10:47 PM   #116
J.R. Haddad
Liked 1,471 Times in 308 Posts
Thumbs down Re: Access to AMA Shipping Weights?
So Kevin, you didn't accomplish what you wanted with the Firebirds,
so you you took one more shot at the 2015 Camaro on the way out??
What are you doing for an encore?
J.R.
J.R. Haddad is offline   Reply With Quote
Old 02-09-2022, 11:18 PM   #117
SS/GSI
SS/GSI's Avatar
What are doing for an encore?
J.R.
J.R., I simply used the 2015 as an example of the "entire" guide NOT being properly revised...the 2015 376ci Camaro is a factory street version car, not a "paper" car(COPO, Dragpak, CJ), yet it still was not corrected by NHRA.
Kevin Gaffney
1123 SS/GA
Old 02-10-2022, 12:42 AM   #118
J.R. Haddad
There are other examples of the same formula, which was started by
Dodge, and approved by NHRA, and I appreciate trying to gets things
straightened out, but these weights have been around for 30, 40, 50
years or more. Now we have NHRA upset that we're upset, some
combo's completely removed, and for what? I will work hard when I
can advance myself, not when I only break even, and all my peers
get hurt.
J.R.
Old 02-10-2022, 12:57 AM   #119
JJurgens
Liked 7 Times in 3 Posts
Originally Posted by Paul Merolla View Post
Bad deal for a lot of people, how about the '83 Camaro 305/200/263? It no longer exists! Guys thought they were almost ready for the season, now they get to spend a load of money adding ground effects and weight just to keep racing the same class. Or spend a load of money adding ground effects, keep the weight the same, and jump up a class! Should be fun for anyone racing at SGMP or Belle Rose.
What he said!!!^
JJurgens is offline   Reply With Quote
Old 02-10-2022, 08:33 AM   #120
Liked 11,032 Times in 2,267 Posts
Has anyone seen anything posted or in writing.
Billy, NHRA did find an odd combo for you to bring to the front: 1971 T/A Dodge Challenger. I don’t know what is the worst make believe, the 71 T/A car or the .527/.527 fffffFFF. Ford camshaft
