#41 | |
Liked 7,912 Times in 1,755 Posts
Maybe they (NHRA) could use their recently enacted Rescission policy!
#42 |
Liked 483 Times in 92 Posts
What class factor is required for a combo to be obsoleted from Stock Eliminator?
I understand that 7.50 is the factor for AA....but can the combo be any amount under 7.50 and still be allowed to run AA? Or what is the lowest threshold class factor still allowed in stock? Is a 6.95 class factor allowed to run in AA still?
Austin Williams 3 SG 464Q STK SC |
#43 |
Liked 1,361 Times in 416 Posts
Not sure I'm on the right subject here. Check out the 71 440 6bbl Roadrunner. It can run A/SA. AA/SA with a Hemi. It is also a natural E/SA with a 340. Some weight got trimmed off that car. Cool makes a new combination in lighter trim.
Paul |
#44 |
Liked 75 Times in 28 Posts
Hopefully the Mopar big blocks 6 pack combos can get an HP break so we can keep up with the others.
The cars have to weigh almost 4000 lbs Trying to run with cars that make the same power that weigh 3400 lbs. It's now like taking a knife gun fight. |
#45 |
Liked 513 Times in 53 Posts
#46 |
So how does the AMA car weight work? I looked at 1970 Plymouth 340 Duster AMA specs. It shows shipping weight at 3105lbs and curb weight at 3269lbs. I get an average of 3187lbs and NHRA shows the shipping weight at 3186lbs. Is that the method or just lucky on one?
Paul |
#47 |
Liked 11,029 Times in 2,266 Posts
I was told shipping weight. All the curb weights are the same on the AMA Sheets for a 70 Cuda, 340, 383, 440, and Hemi. I wonder how NHRA verified the weight of one Cuda with the 340 to the weight of 426 Hemi Cuda?
#48 |
Liked 24 Times in 14 Posts
Paul, help me out here maybe I'm confused. The 71 RR 6pak can run A/SA has a lesser shipping weight than GTX. So RR is a natural B and GTX is a Natural C makes sense, Got it. NOW in 1970 both are natural C and the RR has a higher shipping weight, this doesn't seem right??? RR was always the lighter package.
Frank Bialas 1570 STK Last edited by Frank Bialas; 02-07-2022 at 07:20 PM. |
#49 | |
As Dwight and I explained earlier, the shipping weight was sort of a "Flat Rate" measurement for shipping purposes, that did not take into account the options of the car, just enough gas to move the car around, no passengers, and without cargo. The OEM's did away with shipping weights many years ago and kept the curb weights, which accounts for a car with all fluids, full tank, and standard equipment for the specific model. It is similar to the current curb weight narrative Ford uses for their products and what they weight they recommend for shipping considerations. https://www.ford.com/support/how-tos...of-my-vehicle/ |
#50 |
Liked 2,781 Times in 981 Posts
My question is what prompted the review and adjustments? How often is it done?
I don't recall it happening when I raced in the seventies and eighties. |
