Old 01-30-2022, 05:55 PM   #31
Mike Jones
Liked 684 Times in 289 Posts
Default Re: Sharing
Originally Posted by Al Wilson View Post
I’ve been looking at this. Recently installed these:
https://www.nucapperformance.com/drt.php
Those look like OEM clips from one of the Asian cars from years ago.
Old 01-31-2022, 08:38 AM   #32
Liked 11,007 Times in 2,263 Posts
Default Re: Sharing
On the front end, work to have zero to very little toe change through the range of travel. For us that took awhile. Good luck!
Get the car the best it can be first, then when a change is made it will respond positive or negative. The days of a 20 Hp improvement with a cam and spring change are gone for most of us. I fight all the time to make the second number right of the decimal point smaller on the et slip.
Hope this helps.
Old 01-31-2022, 10:33 AM   #33
jmcarter
jmcarter's Avatar
Liked 3,244 Times in 986 Posts
Default Re: Sharing
Budget permitting, ceramic bearings. Ever notice someone pushing a car almost effortlessly in the staging lanes? Yep, you guessed it.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-31-2022, 11:09 AM   #34
SSDiv6
Default Re: Sharing
There is a lower cost alternative to ceramic bearings; DRP Bearing Spacers.
https://www.drpperformance.net/hub-components
Old 01-31-2022, 12:55 PM   #35
Al Wilson
Liked 109 Times in 38 Posts
Default Re: Sharing
I installed those based on your tip in another thread. They obviously didn't have any for a AMC Spirit, so they custom made a set (after giving them some dimensions) for the same cost as a stock set. I went with a different company for polished bearings as they had mine in stock:
https://negearpolishing.com/services...ring-seal-kits
Al Wilson
NSS 7160
W201 stock
Al Wilson is offline   Reply With Quote
Old 01-31-2022, 01:41 PM   #36
Default Re: Sharing
There’s a lot of good parts in bar stock and they’re easy to find. All that has to be done is cut away everything that doesn’t look like what you want.
Old 01-31-2022, 10:33 PM   #37
Default Re: Sharing
If you need access to a lathe try an adult education at a higher learning center. It will be fun and save you a few bucks in making that special piece. Explain to the instructor what and why you want to do this special project. You’ll learn a lot but don’t hurt yourself. The machine doesn’t now the difference between steel , aluminum, or fingers, it will cut all three.
Old 01-31-2022, 11:55 PM   #38
HR9121
HR9121's Avatar
Default Re: Sharing
Originally Posted by Glenn Briglio View Post
I believe this is common knowledge but I'll share anyway. Easy way to pickup hp and et. Remove 1 quart of oil. But pay attention to oil pressure going down the track if you've never done this before. An oil accusump would also be a good idea.
Glenn I forgot who it was that told me 72 ounces was all I needed. I shuttered every time I thought about it.
Also another good one, "Rpm's are your friend."- Mr Garley Daniels
Spoken like a true engine builder!
James Williamson
W200 J/SA. SS/JA
Old 02-01-2022, 09:31 AM   #39
Default Re: Sharing
Mr Daniels would know.
Old 02-01-2022, 10:23 AM   #40
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
Default Re: Sharing
2.25 qts man you must hate your engine..........lol
Glenn Briglio is online now   Reply With Quote
