Old 01-08-2022, 05:36 PM   #11
james schaechter
Liked 1,443 Times in 302 Posts
Default Re: Lets put the "I" back in Stock Eliminator
Originally Posted by Dan Walcott View Post
Robin, I respect your input
I feel the injected cars have an advantage.
They are more efficient cylinder to to cylinder than a carburetor
I'm not a key board wiz , more of a knuckle buster at best.
I don’t think any of this matters as long as the factor is right. There are plenty of carb combos that are competitive. I think people point the finger at injected combos because some of the soft ball combos for new cars were crazy bad and of course, they would all be FI . F I alone is ok as long as the hp factor is reasonable.
There are FI combos that are good and there are some that are not so good.
The crazy part is that AHFS could work if the executive bean counters would make it worthwhile to run the cars out once in awhile.
Dan, typically posts like the one you started with have some Ideas. Let’s hear specifics. If you don’t believe in it enough to share, why did you post it?
James Schaechter 3163 STK
Old 01-08-2022, 05:57 PM   #12
Jeff Niceswanger
Liked 1,072 Times in 379 Posts
Originally Posted by Robin Lawrence View Post
There is some truth the the Cylinder to Cylinder efficiency. While the current systems allow trimming cylinders I think that the designs of the manifolds played a big part. The OEM's in an effort to make cars more efficient really stepped up on manifold design.
I wasn't asking to be a smart ***, Since I work for a company that has some history in fuel systems I have heard many opinions. I have friends and customers who swear that their Carburetors make more power and are more consistent. On the other side I have the people who say that Open loop fueling verses Closed loop is better for their program.
If you have raced many carburetor cars over the years as well as Injected cars I would like to hear your opinion. Since I have not actually competed with a carburetor my opinion would be biased to what I know. Actually I think that with the fuel injection there are more ways to get an inconsistent run with all the variables. But again I would love to hear from those who run both.
I have tried very hard to tune or create a program that eliminates or is less effected by the various inputs in my system.
Robin
Robin, Our 993 Q-Jet motor of Gulius made 615 HP. He built us a new L-98 (240/270) in 2014 that was just like the 993 except required FI. It had the 083 OEM heads. John had no way of breaking the FI in as this was his first go round with it, so we put it on the dyno in Q Jet trim. It made 638. Shortly after we were able to get the dyno up and FI ready. To our surprise ...we lost 18 HP. That little 48 mm throttle body was just too small. I have heard many similar stories, but I know this one first hand ..
Jeff Niceswanger 3740 SS
Old 01-08-2022, 06:56 PM   #13
my69396
Liked 46 Times in 20 Posts
How would combining sticks and auto's fix AHFS?
my69396 is offline   Reply With Quote
Old 01-08-2022, 08:13 PM   #14
GUMP
More heads-up runs.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 01-08-2022, 08:45 PM   #15
Robin Lawrence
Sponsor
Liked 717 Times in 121 Posts
Originally Posted by GUMP View Post
More heads-up runs.
If it was in FS/G you would be losing......... hahaha
Robin
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
Old 01-08-2022, 09:43 PM   #16
GUMP
Does Holley make a trailer hitch for a Gen 6 Camaro?
Daren Poole-Adams
NHRA Stock/SS 2007
Old 01-09-2022, 02:24 PM   #17
lstanford
Liked 134 Times in 32 Posts
Let's put the "Common Sense" back in Stock Eliminator!
The problem with common sense is that it is not common.
lstanford is offline   Reply With Quote
