Old 12-24-2021, 11:21 AM   #1
1347
1347's Avatar
Liked 988 Times in 272 Posts
Default Off season maintenance/upgrades
For some this has already started, for others it will be starting soon. What is on your list for this offseason, as the start of the new season is creeping up on us.
For me it consists of taking engine and trans out, checking bearings, touching up heads, going thru the trans. upgrading to 5/8th wheel studs.
Normal wheel bearing, brake maintenance, and some wiring work.
Also upgraded to a trailer based weather station. Then we will go back on the dyno before we put it back in the car.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 12-24-2021, 03:49 PM   #2
Bob Lasko
Bob Lasko's Avatar
Liked 185 Times in 54 Posts
Default Re: Off season maintenance/upgrades
Had the engine upgraded with new crank and other little things.
Most important think that I did was to clean the under chassis of the car and while doing so, found a split in the right frame rail. also found a crack on the weld for the rear engine plate.
I do this every year, never know what you can come up with.
car now in the trailer for the winter and when it coms out, new heim joint on the four link and a wax job.
Bob Lasko
Old 12-24-2021, 03:56 PM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Ford 302 with N351 heads in a '68 Mustang coupe. Repaired glass hood and fabricated trick hinges to make it hinged and removable with no tools. Updated electrical system to make it coherent to tech. Upgraded to manual brakes with pressure gauge. Cleaned heads and replaced 250/750 springs with more sane 210/520s. New bearings all around-triple checked clearances.Reinstalled Crane cam with 351 HO firing order. New file fit rings. Got my high stall converter to fit. Trans brake solinoid shorted out last year, need to get to that. Going to add an air shifter to hit the 1-2 only so I can keep my hands on the wheel more. Want a better gas pedal to go with my better brakes. I spend half the winter taking stuff off and half looking for it to put back on.
Dale Shearon
68 Mustang 6394
Old 12-24-2021, 06:27 PM   #4
Liked 10,681 Times in 2,222 Posts
Adding more Classic Insturments in the 40* to 220* F range.
Old 12-24-2021, 07:42 PM   #5
Carl Siwek Jr
Liked 13 Times in 4 Posts
some new wheels here
Carl Siwek Jr.
I/SA 1908
Carl Siwek Jr is offline   Reply With Quote
Old 12-25-2021, 01:26 AM   #6
Casey Miles
Liked 488 Times in 90 Posts
I had the clock turned back to where my Camaro looks better than the day I got it almost 50 years ago. Also dropping new power plant between the frame rails. Should be fun.
ID:	61586   Click image for larger version
Old 12-25-2021, 11:30 AM   #7
Ken Kopecky
Liked 273 Times in 56 Posts
For me, I upgraded to a new tow vehicle. I just took delivery of it 2 weeks ago. 2022 Ford F350 with the 6.7L Power Stroke diesel. Getting it ready to tow the trailer with getting the bed hitch plate and in bed wiring installed. Plus an exhaust and air intake upgrade over the stock parts to hopefully increase the mileage. Graphics to go on next month.
Ken Kopecky
Ken Kopecky is offline   Reply With Quote
Old 12-25-2021, 11:46 AM   #8
SSDiv6
Liked 1,575 Times in 580 Posts
Busy taking apart a 2016 Mustang to install a 7.50 cage and converting to a 3-Link rear suspension for N/A Factory Stock.
Old 12-25-2021, 01:56 PM   #9
Bill Hawk
Liked 20 Times in 6 Posts
looking for to find hp
Bill Hawk 1352 STK
Bill Hawk is offline   Reply With Quote
Old 12-25-2021, 03:56 PM   #10
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Mostly to my execution of a plan. You can't win without it.
