Liked 17,488 Times in 1,595 Posts
Hey guys, I just pulled in... I have not been to this track for over 10 years, man how things have changed. Anyway, as most of you know the schedule has changed. Sportsman will get 2 rounds of eliminations instead of 1. Stock will be out first at 8:30am and then its the typical rotation until eliminations... things will be moving fast tomorrow.
I will do my best to get photos, I do have media credentials, but I may not have time as the sportsman are on a tight schedule. If I get a good run in our first qualifier, I'll skip the second, that should give me plenty of time to get some starting line shots. The weather tomorrow looks good, but Saturday looks a lot cooler and rain in the morning. I did find a few cars out... |
#2 | |
Liked 496 Times in 234 Posts
Jake Biermann |
Liked 4 Times in 3 Posts
I believe that is Kyle Anderson I/SA 350 Malibu wagon
Kenny Miracle P/SA 310 |
Liked 226 Times in 137 Posts
8:25 am
temperature = 61.91 deg f relative humidity = 97 % uncorrected barometer* = 28.43 inHg corrected barometer* = 30.00 inHg wind speed = 2.15 mph wind direction* = SE (162°) more info: current metric | historical | forecast | help dew point = 61 deg f saturation pressure = 0.558 inHg vapor pressure = 0.542 inHg grains = 84.5 air density (w/o water vapor) = 95% air density (w water vapor) = 93% density altitude = 2513.07 ft |
Liked 2,765 Times in 978 Posts
Is there no live timing from Bristol this morning?
Liked 10,931 Times in 2,258 Posts
No live timing, what a gyp!!!!!!!!!!!!!!!
Good morning all, no live timing... not sure what the issue is. There is no one here that I can talk. I went to get my media vest and there is still no one around. We just made our first shot down the track, and it was pretty foggy but the track seemed ok. Its slow here as always, bar is 28.45.
I have to make another run so photos will be a little light this race. I will do my best to get some shots. If anything I will get shots from the pits or the stands. Be back later... |
It just came up.
Hey guys I'm back, we are moving quick, Super Stock is in the lanes for their 2nd qualifier. First round for Stock should be up in the next hour or so. I did manage to get some phots of Super Stock. Here is one set, I will have more later. If I go out early I will get photos for Stock.
A problem with schedules like this is if you break something you are out of luck! there really is no time between runs or eliminations to get anything done. it’s so sad, even if you did break something you’re not going to go into the manufacturer’s midway and get the parts you need. Boy, how things have changed!!!
