Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 09-25-2021, 09:30 PM   #1
DailyDriverSst
Liked 7 Times in 6 Posts
Default Battery mounting directions
Right now I have my 1 battery mounted parallel to the bedside, in right front corner of the bed.
I'm wanting to move it to the right rear corner of the bed, and add a second battery.
I recall being told that a wet battery should be mounted a specific direction, because acceleration can cause plates to short out. Is that lengthwise or transverse?
I'm also considering adding a second battery. Should I put both batteries together in RR corner, or put second in left rear corner?
Front axle: 2,470 pounds
Rear axle: 1,740 pounds
Total: 4,220 pounds
(plus my 190 pound self)
DailyDriverSst is offline   Reply With Quote
Old 09-27-2021, 06:25 AM   #2
Hacksaw
Liked 314 Times in 177 Posts
Default Re: Battery mounting directions
Mount your second battery in RR corner and the plates should be parallel with the driveshaft.
Old 09-29-2021, 11:20 AM   #3
340Cuda
Liked 805 Times in 341 Posts
I would agree unless you are using an Optima, they are spiral wound so it does not make any difference which way they go in.
Old 11-13-2021, 01:26 PM   #4
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Total: 4,220 pounds
If this is a class car, remember both batteries must be of the same make and model. No 75lb. battery in the rear and a 15lb battery in the front. Jim
