#31 |
Mark, good time to upgrade those hub bearings to some nice, low drag ceramic pieces!$$$
#32 | |
Liked 5,153 Times in 1,967 Posts
#33 |
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 04-28-2021 at 12:32 AM. |
#34 |
Liked 373 Times in 129 Posts
Looks great!
#35 |
Nice progress, Mark. Header looks great. I`m guessing the water pump needs to driven off the timing belt, so no way to run it electrically?
#36 | |
The Motorcraft PW 611 electric pump is going into the lower hose.If it's good enough for the 2016 302 Cobra Jet, then it's good enough for me. Going to match up a bottom hose tomorrow and then build a bracket to hold it. No, you can't buy one at Jegs or Summit.. ;-) Pics to follow.
#37 | |
Liked 49 Times in 15 Posts
It used to read "Electrically driven fans and water pumps permitted. Water pump must bolt on, with no modifications to block."
Dean Feiock -- Stock 5002 |
#38 |
This particular water pump is an OEM water pump and does not require any modifications to the engine block.
#39 |
Liked 309 Times in 88 Posts
Mark, great detail work.
Jimmy Parker |
#40 |
Please see my post in S/SS Tech ..EFI Help Needed
Thank you.
