#31 | |
GL-5 has a higher EP (Extreme Pressure) rating than GL-4 and it offers a higher shock load protection when you have a high angle of gear contact. GL-4 gear oil, no matter the viscosity, has half of the sulfur/phosphorous additive that gives the shock load protection. Nevertheless, because of the different angle of gear contact and softer contact material, on a manual transmission, this same additive used on the GL-5 gear oil effects the syncros and other soft metal components by fretting the contact surface. |
#32 | |
Liked 133 Times in 76 Posts
