#41 |
Liked 959 Times in 192 Posts
I currently have a 5;57 and a turbo 350 trans with a 2.74 first gear. The little motor really likes a lot of gear.
#42 | |
Liked 147 Times in 54 Posts
Randy Hyman. Lakewood co. stk 5394 P/SA |
#43 |
It has been awhile but I'm back working hot n heavy on the 55 Q" ship". Body is in the body shop with a late March delivery date promised. I have the powder coated frame at home in the garage trying to get as much done on it as I can so it will be easy swap over when the painted body gets back from the painter. Even going to try and get the brakes bled so I can test all lines, fittings, and new flares for leaks. I will show you how I'm going to do that with the master cylinder mounted on the new frame, and powered up with a pressure bleeder. Engine block is on the engine stand and with the arrival of a few more pcs I will start putting it together in the next week or so. I found one of those rare 548 casting 283 blocks made with the 265 bore. The block is called a poor mans Bowtie, as it has thick walls, and deck. It even got a mention in Grumpy's first small block engine build book. I would really like to have the car ready to test by the end of April but that is going to be pushing it by any means.
#44 |
Liked 18 Times in 5 Posts
#45 |
Liked 308 Times in 173 Posts
#46 |
Liked 5,109 Times in 1,947 Posts
#47 |
I have a Impala 12 bolt with spool.
#48 |
#49 |
Liked 316 Times in 67 Posts
FWIW: at one time Speedway Motors in Lincoln, NE had a stockpile of NOS Firestone 7" slicks, I'll bet they would work
Just a thought |
#50 |
Yes the old blue dots would look cool on it just sitting in a display somewhere, but I will stick with my Hoosier 9 inchers for going down the track. Will be faster and a lot more stabile.I think Coker tire did at one time a few years ago make some repos of the M+ H 7 inchers also.
