Old 02-18-2021, 11:22 AM   #41
Hacksaw
Liked 314 Times in 177 Posts
Default Re: Over Staging
Originally Posted by GTS340 View Post
After your burnout, roll up to the line, light one bulb on the tree. Do not light the second bulb until the car in the other lane has at least lit one bulb. They can roll in and light both bulbs if you already have one lit but nobody should light both bulbs until the other car has one lit.
Best I can find
You are describing courtesy staging and that has nothing to do with the new ruling. The new rule needs some clarification such as what is the call if the car lights both bulbs and then creeps ahead enough to put out only the pre stage light? Can he back out and re stage or is that a DSQ? I've seen this happen LOTS of times.
Old 02-18-2021, 11:52 AM   #42
GTS340
Liked 1,355 Times in 414 Posts
I guess we'll find out the next race. I hope I'm doing it correctly
Old 02-18-2021, 12:12 PM   #43
GTS340
I'm sure I'm wrong and your correct. So go ahead and turn on both lights and back out.. over.
Old 02-18-2021, 12:28 PM   #44
Jeff Stout
Liked 707 Times in 284 Posts
No I'm describing this I believe.
This is a courtesy stage problem, not a new rule problem.
Old 02-18-2021, 05:13 PM   #45
Mike Volkman
Liked 513 Times in 53 Posts
Hot off the press! From NHRA Racer
Policy Update - Over Staging (Clarification)
If a driver/rider should "over-stage" (driving completely through BOTH the Pre-Stage and Stage beam in the process of Staging) in any category during eliminations, that driver is not allowed to back up and re-stage. That run is disqualified resulting in a round loss for the competitor.
Return to Updates
Mike Volkman is offline   Reply With Quote
Old 02-18-2021, 07:22 PM   #46
Keith 944
Keith 944's Avatar
Good, That's what i was thinking.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
