Old 12-25-2020, 05:28 PM   #1
lewis Becker
Liked 15 Times in 8 Posts
Default Opel-opel gt
Opel-opel gt-they are in the guide!
Zinga.
lewis Becker is offline   Reply With Quote
Old 12-25-2020, 08:53 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Opel-opel gt
Opel was owned by GM until 2017. Maybe put a 327 in a 68-69 Kadet for SSGT?
Dale Shearon
68 Mustang 6394
Old 12-26-2020, 12:22 PM   #3
lewis Becker
interesting idea!...maybe a 3.8 combo,ect.
Old 12-27-2020, 01:24 PM   #4
BTR69
BTR69's Avatar
Liked 74 Times in 24 Posts
Really love reading about your builds. Hopefully I can get restarted on mine and contribute here with it. In the meantime, since the Opel was brought up, here's one, (not mine), if anyone's interested. Found it advertised while wasting time online last night. Have a great weekend...
https://onslow.craigslist.org/cto/d/...243067703.html
William Kilduff
1970 Barracuda (still under construction, indefinitely)
1968 Camaro SS/C
BTR69 is offline   Reply With Quote
Old 12-27-2020, 05:16 PM   #5
Rory McNeil
Liked 1,103 Times in 301 Posts
Opel GTs are pretty cool, not sure if the wheelbase is long enough though. Also likely be a bit tough trying to fit a carbed V8 underneath that very low hood, maybe a EFI setup would fit. not to mention getting any size tire in those tiny wheelwells and very short overhang.
NHRA 6390 STK
M/S 85 Mustang
Old 12-27-2020, 06:34 PM   #6
FireSale
FireSale's Avatar
Minimum wb is 85 inches. 68 Opel GT is 97.7. Kadett 91.5. I know the GT was popular in the old Modified classes, but there was more leeway with the body for fitting a V8 in the bay built for a 4 bannger. Might be difficult with the SS and GT rules. Does GM make a good 4 or 6 cylinder? If this were a Ford body I'd look at a 4 cylinder Echoboost
EDIT: SS/Modified Stock could work. SS/DS is 6 cylinder, SS/ES is 4 and SS/FS is small displacement engines. Fiberglass hoods with scoops are allowed. Lots of leeway with engine building.
Dale Shearon
68 Mustang 6394
Old 12-27-2020, 10:02 PM   #7
Liked 5,113 Times in 1,948 Posts
Forget the GT ,if you want to get it into W/Stock...a 4 cylinder only class.
You can make it with a 71 1900 series. I don't know what that is, but I seem to remember it not being too attractive..That's the good news.
90 hp isn't a bad rating but..no compression, .370 lift cam, good luck getting a cam blank, pistons.
Solex 2bbl. various jets ???
Pass...
Old 12-28-2020, 03:57 AM   #8
FireSale
FireSale's Avatar
And a reasonable man pops another bubble of wild stray thoughts...
Dale Shearon
68 Mustang 6394
Old 12-28-2020, 02:10 PM   #9
SSDiv6
Liked 1,576 Times in 581 Posts
Pass...
Mark,
This place has probably everything you need for an Opel GT, including headers, cams, suspension, etc...
Solex carbs are easy to work on and there are many sources for jets.
https://www.opelgtsource.com/catalogs
