#21 | |
Liked 251 Times in 125 Posts
Although that's where I learned what an out of time distributor sounded like, I learned more about shady car guys that day. (turned out, the Imp was a 300 hp 350, and the heads were swiped and replaced with whatever Chevy heads were cheap. I'm not a Chevy guy and don't remember.) The car did run smooth as glass though, until I seized it in cold weather running straight 30w. But that's another story. |
#22 |
Liked 520 Times in 176 Posts
The long straight limb on the apple tree wouldn't hold up the Hemi, so we sured it up with 2"x4"s. got it just high enough and had to let some air out of the tires , tough to push but got it in!
#23 |
#24 |
Liked 707 Times in 284 Posts
My first car. 55 Chevy 210 Hardtop. put a 327 and 3 speed. Kept breaking trans. Put a 4 speed in and starting breaking spider gears from wheel hop. Bought a set of slapper bars and had to elongate hole. While under car with grinder I had metal get into my eye. I was 16 and dad took me to emergency room and they numbed the eye and drilled out metal.
#25 |
Stories... What else have we got!
John DiBartolomeo DRC Race Products DragRacingActionOnline.com |
#26 |
![]() Johnny - Guys our age don't have much racing left but have plenty of stories .......
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
#27 | |
Come on man... Whaddya mean "not much racing left?"
#28 |
Liked 55 Times in 22 Posts
These stories bring back so many memories of my youth, that I had to reply. My Dad and I started drag racing when I was 14 years old(1968).
We'd been racing his drive to work '66 chevelle, and he didn't want to risk a failure and have no work transportation. We bought a 1960 Impala w/ a 305 horse 348 "W" engine and a powerglide. We brought it home and the only place to pull the engine was in the back yard under the big Maple tree that was strong enough to hold the 1,1/2 ton chain fall and the engine/ transmission. We were able to maneuver the engine out of the car and down to the ground, but how to get the engine into the garage which was 125 feet away. My 1st attempt at brilliance(I've had many failures since) was to remove the tranny and mount the engine on the engine stand. Fine, but it won't roll across the grass. I got 2 4x8 Plywood boards and rolled the stand onto 1, move the board, roll again, move the board. You all get the idea. It's now in the garage and I'm learning how to build a Jr. stock eliminator engine. Cool? Well it was if I knew than that the pistons have to go in a certain order, because the cylinder is the combustion chamber and there are valve reliefs that are staggered to match the valve in the heads. I installed the pistons wrong, and although the engine fired up and ran, it bent a couple of intake valves when they hit the piston tops. So imagine the whole process of board moving, installing, running, and then repeating it to re-build the engine again. My father was none to pleased. I never did that again, even after pulling the engine each fall to "freshen" it. To quote the late Dan Fogelburg: "Lessons learned are like bridges burned, you only need to cross them but once". I hope everyone has a wonderful Christmas, and remember why we celebrate the day. God Bless, Walt |
#29 |
![]() Don't know about you but I'm sure I won't be racing ten years or less from now .
#30 | |
Liked 719 Times in 220 Posts
