Old 10-13-2020, 12:09 PM   #101
GTX JOHN
Liked 2,471 Times in 696 Posts
Default Re: stockers
You can buy a piston from any manufacture = Tell them it is for superstock or a bracket car maybe some other non stock eliminator use. Then lazer cut the NHRA approval on it yourself - Is that your violation and did you not mislead the manufacturer of your purpose?
John Irving
741 Stock
741 Super Stock
Old 10-13-2020, 01:29 PM   #102
SSDiv6
Liked 1,577 Times in 581 Posts
John,
I believe that could be the scenario. However, the question is if they would admit they did it or blame the piston manufacturer and give them a black eye? It is a can of worms! If it keeps happening, I can see NHRA allowing any ring package and doing away with something else to inspect.
Old 10-13-2020, 01:49 PM   #103
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
When did that all happen ?
The Duster incident happened last year at the Joilet points meet. He was the D3 rep in stock and could hardly run the index (post teardown) after going consistently .80-.90 under for years. I've been through many teardowns and NEVER lost 8 tenths or more.
Jon Sarrett
Stock 3779
Jon Sarrett is offline   Reply With Quote
Old 10-13-2020, 01:54 PM   #104
jmantle
Liked 172 Times in 81 Posts
Originally Posted by James Perrone View Post
And the guy accuses people of Obvious cheating. Races .... a Pacer
Really ?So Captain obvious what do you see
I'll give you an example, a few years back a friend of mine was proudly showing me his cylinder heads that he'd payed big bucks to have done by a "professional". The crossover passages were filled right into the port and the area had been nicely blended in to look like the crossover never existed. Legal? Not if you read the rulebook but I know some racers that never do. Deliberately cheating, probably not.
As far as my Pacer goes, if you want to see inside the engine I'll tear it apart just for you any time you want.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 10-13-2020, 02:01 PM   #105
bykr
Liked 167 Times in 81 Posts
John,
Especially now with gas ported rings that are essentially legal.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 10-13-2020, 02:17 PM   #106
Liked 5,113 Times in 1,948 Posts
John,
Joe, Of course, the ring height can be measured with the head off, so what 's NHRA's problem with checking it?
If they go that route, then REAL replacement Stock pistons are at even more of a disadvantage. Another shot at the budget racer, and another rule revision rammed through by the cheaters.
So then what happens? Under weight pistons and rods? Knife edged cranks?
Where does it end?
Old 10-13-2020, 03:41 PM   #107
SSDiv6
Where does it end?
Fully agree with you Mark! it can be checked easily. I have not seen anyone thrown out by illegal pistons that has been made public by NHRA.
I just pointed to a plausible aftermath with everything that has taken place in the past.
Old 10-13-2020, 03:44 PM   #108
SSDiv6
Tim,
Thin piston rings with spacers have been allowed for a long time. There are lots of piston ring designs that can achieve the same as the gas ported rings. At the end of the day, it is having the ring hone finish, a round bore and compatible rings that make the power.
Old 10-17-2020, 10:03 AM   #109
Cbrinson47
Liked 56 Times in 33 Posts
Unhappy Re: stockers
I wonder with the pushing of limits in Stock and the difficulty with tech inspections, would NHRA ever fold Stock into Super Stock?
Stock is ALMOST a S/S class now !
Cbrinson47 is offline   Reply With Quote
Old 10-17-2020, 11:37 AM   #110
Carguy49
Liked 2,928 Times in 703 Posts
Without tech and integrity of the racers Stock is long gone.
I have heard that if you build a stocker strictly by the rule book, you are behind the eight ball. I know there are some exceptions, but just sayin'. I don't fully understand but that's what I heard, a few years ago.
Ron McDowell - Did Race
