Old 08-06-2020, 12:28 PM   #1
Chris Hill
Liked 244 Times in 26 Posts
Default Physics of Racing Torque Converters
Can anyone share the main governing equations for torque converters?
I think Russ Abrahams (sp) had something, but I can't remember them at this time.
Chris Hill
Old 08-06-2020, 02:53 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Physics of Racing Torque Converters
One of the formulas is K=n/square root T
K is number that is the looseness of the converter
n is the stall speed
T is the engine torque
Russ Abrams 3011 GT/FA
Old 08-07-2020, 09:53 AM   #3
Dragsinger
Liked 99 Times in 60 Posts
some years ago Brandon with BTE did an extensive and informative series about a - z on the subject. Maybe that post is somewhere in the archives.
If it can't be found, maye Brandon would repost the series.
Larry Woodfin 471W
Old 08-07-2020, 10:05 AM   #4
Chris Hill
Russ, thanks for the reply.
Units are rpm and ft*lbs?
But there must be something about torque at an rpm.
Say you have an electric motor with a flat torque curve of 500 ft*lbs and you want stall of 6,000 rpm.
What additional info is needed?
Chris Hill
Old 08-07-2020, 11:21 AM   #5
ss3011
ss3011's Avatar
That is the whole point of that formula . You have to develop a K factor that gives you the rpm you want with the torque you have at that rpm . In general you have different stators and different pumps that will give you a combo that matches the K factor desired . units are in rpm and ft.lbs.
Old 08-07-2020, 01:01 PM   #6
jmantle
Liked 172 Times in 81 Posts
If you can find a copy, "design of single stage, three element torque converters" by V. J. Jandasek explains torque converter function very well, including K factor. You might be able to get a copy from the SAE or it is in the third edition of "design practices, passenger car automatic transmissions", published by the SAE.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 08-08-2020, 12:28 AM   #7
Dissident
Liked 73 Times in 36 Posts
It might seem insignificant to most, but when you try to do math without using the correct units one will get incorrect answers.Torque is a twisting force and is typically expressed in lbs-ft while work is typically expressed in ft-lbs (energy). Yeah I know that seems to be nit picky but it makes a difference when you practice unit cancellation in the mathematics on the subject material.
Regards,
HB2
Dissident
Dissident is offline   Reply With Quote
