Old 08-05-2020, 03:23 PM   #1
west coast
Liked 230 Times in 75 Posts
Default Powerglides
Powerglide 1.76 gear, Reid case has expired. Turbo spline input. Built by Hughes with there parts and Brake $1700
Powerglide 1.80 straight cut gear, Reid case has expired. Turbo spline input. Hipster valve body and brake. After a rebuild had to stage with higher rpm then idle. Is missing a check ball when put back together. $1700
Powerglide 1.76 gear, stock case. Turbo spline input. Built by Hughes, Hughes valve body and brake. $900
Have 2 stock powerglides one 8cyl, 6cyl $ 50 each
Have a stock PG case $25
Brand New Reid 2 piece case with chevy bellhousing but has expired $500 SOLD
Reid case slighty used great shape, expired $500
Hughes Converter BS9D 1.125 $400
Have Pictures I can text, for more info PM me, will be in Boise
All this was behind S/G S/ST car with BBC
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 08-08-2020, 10:08 AM   #2
63corvette
Liked 362 Times in 105 Posts
Default Re: Powerglides
I am about to send you a PM
Thanks
Rick Cates
Canyon, TX
63corvette is offline   Reply With Quote
Old 08-17-2020, 02:20 PM   #3
chevy2
chevy2's Avatar
Liked 52 Times in 5 Posts
PM sent. . . . thank you.
chevy2 is offline   Reply With Quote
