Harmonic balancer weight and its effect on performance?
If one reduces the balancers weight and makes correction to any imbalance on the crankshaft. Might one see an increase in HP and how quick the engine spins up? Thanks Bernhard |
Liked 494 Times in 241 Posts
Theoretically yes... enough to notice?... I doubt it.
How much can you take off a balancer?... a lb maybe? It's not like taking 10 lbs off of a flywheel. Just an opinion, others may know more. |
The above, and the smaller diameter of a dampener, versus a flywheel, the effect on inertia won’t be big.
Ed Wright 4156 SS/JA |
Liked 733 Times in 384 Posts
Exactly. Plus it also depended on how fast the rate of acceleration of the engine is. A 1 lb weight on the outside of a 6" diameter accelerating at 2000 RPM per second at 7000 RPM is taking less than 0.54 HP. Where as that 1 lb on the outside of a 12" diameter accelerating at 2000 RPM per second at 7000 RPM is taking 2.17 HP.
Stan |
Liked 556 Times in 69 Posts
I put it in the category of things that dont show a measurable increase but when added to 50 other things like that, all of a sudden your a little faster. Lol
Thanks you for your insightful replies to my question.
Bernhard |
Liked 6 Times in 2 Posts
I'll add a couple things with no verifiable info to suggest I'm correct however.. Almost all balancers are neutral or zero balanced so a change won't affect anything internal. Smaller/lighter should spin up faster but as mentioned, you'll never notice it. What is important is the name "Harmonic". A small lightweight balancer can't control internal harmonics like a heavy "factory" one does. Bearing or crank failure can be the result. Some engines and balancer brands are notorious for this.
Hopefully, a real expert chimes in here but i can guarantee you'll se nothing performance wise. Kinda similar to Roller Rockers that are magically going to add HP> JMO
Dale Posnick |
#8 | |
Liked 2,471 Times in 696 Posts
added to 50 other things like that, all of a sudden you're a whole lot poorer. Lol AND THEN = Your crank is in two pieces!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 08-03-2020 at 01:31 AM. |
#9 | |
Ended up with stock in Federal Mogul and had lots of two piece door stops! |
Liked 33 Times in 20 Posts
