Old 06-15-2020, 12:27 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Cleaning Trailers
Before racing this weekend.
Scrubbed and clean the Featherlite Trailer with Cleanser.
Did ok
Got most of the mildew.
It needs a better cleaning.
What product is out there that does a good job?
Dan
Old 06-15-2020, 05:34 PM   #2
FED 387
Liked 336 Times in 183 Posts
Default Re: Cleaning Trailers
try simple green --just spray it on let it set a minute then use one of those windshield bug scrubby sponges and use a soft toothbrush in the corners ---rinse immediately top to bottom--do a section at a time don't try to do the whole side all at once---FED 387
Old 06-16-2020, 11:32 AM   #3
Dan Fahey
Dan Fahey's Avatar
Thanks...
D
Old 08-09-2020, 04:44 PM   #4
Chuck Gallagher
Liked 134 Times in 28 Posts
I found that 5% distilled white vinegar and 95% water and a scrub brush cleans and stops the mildew.
Also, after scrubbing, don't rinse it off right away to allow the vinegar some time to kill all the mold. About an hour should do.
A gallon of pre-mix can be bought in most grocery stores for under a dollar. Good luck.
Chuck
Chuck Gallagher is offline   Reply With Quote
Old 08-14-2020, 12:17 PM   #5
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
Did ok
Dan
Go to the Dollar tree/ Dollar General and get some "LA's Totally Awesome". Its a yellow cleaner in a clear bottle. I buy it by the case. Don't spray it full strength on the trailer, It will leave clean streaks where ever the cleaner was. I mix a bottle of it in the bucket every time I clean the motorhome or trailer. That stuff will clean anything, I use it in the washer with my work clothes, to clean the BBQ etc.
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
Old 08-15-2020, 10:53 AM   #6
340Cuda
Liked 805 Times in 341 Posts
Any recommendations on something that works well with a power washer?
Thanks,
Bill
Old 08-16-2020, 07:56 PM   #7
Steve Polhill
Thanks,
Bill
I brush and a bucket LOL
Steve Polhill
3520 STOCK, COMP
Old 12-27-2020, 12:32 PM   #8
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
Just purchased a trailer from Texas that had been stored outside all of its life. Great little trailer but in dire need of cleaning.
So........after trying Simple Green and then Totally Awesome, (diluted), in conjunction with a medium stiff scrubbing brush and warm water, it was clear this wasn't even coming close to touching the water stains.
I tried the following:
Variable speed buffer and medium sponge buffing pad with 3M #1
rubbing compound mixed down with water. It took about 6 hours and a 12 pack to complete.
Worked for me.......
ID:	56525   Click image for larger version
ID:	56526   Click image for larger version
SC 707Y
Dano is offline   Reply With Quote
Old 12-27-2020, 10:49 PM   #9
1matcoman
1matcoman's Avatar
Liked 367 Times in 141 Posts
Thumbs up Re: Cleaning Trailers
Looks good!!! (and sounds like a ton of work!!)
Old 04-14-2021, 03:29 PM   #10
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Totally Awesome is very aggressive and I think it removes the wax... I use it right before I am going to wax my trailer. Gets rid of black (I have a white trailer) streaks, What ever you do, don't let it dry on the trailer.....
