Old 06-01-2020, 10:24 AM   #1
StompNDump
Default Do these stop numbers sound right?
582 in a Davis Roadster, All out runs 850's
Dedenbear Delay Box, APD Max Speed carb
Launch 5200
Timer A1 - .125
A2 - 3.050
Shift (Timer) B1 - .200
B2 - .300
4100 RPM while on Stop
MPH was 152 and car ran a 10.56
Changed Timer A2 - 2.050 and car ran 10.19
I just got this car turn key and im kinda new to all this. Just wanted to see if these numbers looked correct or if there is something that looks incorrect. The 582 is nothing fancy, Id say a mid range 582 with the weakest link being BB2X Xtra Heads.
StompNDump is offline   Reply With Quote
Old 06-01-2020, 12:17 PM   #2
57 Vette
57 Vette's Avatar
Liked 38 Times in 14 Posts
Default Re: Do these stop numbers sound right?
Is the Davis 57 model or a C5? I have a 57 Davis that has a 582 Head Hunter engine that makes around 1060 H/P. # 1 timer .007 # 2 3.500
Shift .020-off .040 I leave at 5,200 to 5,600 Rpm. All these numbers are depending on the Density Alt.
57 Vette is offline   Reply With Quote
Old 06-01-2020, 01:02 PM   #3
StompNDump
Its the C5 Davis
DA was 1803 Ft
Old 06-01-2020, 01:41 PM   #4
57 Vette
57 Vette's Avatar
The C5 model Davis is a good 100 lbs lighter than the 57 model and has better aerodynamics!
Old 06-01-2020, 02:45 PM   #5
StompNDump
It was those numbers that had me guessing. I figured a engine that size running 8.50s would have carried more in the timers or at least close to where they were set, but unfortunately that ended in a 10.56 and 10.19, So it looks like this set up may only carry a second or so on stop.
Old 06-02-2020, 08:43 AM   #6
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
If it were mine, I'd make the 'Stop On' time later and/or increase the RPM on the stop some so you can carry a little more time on the stop.
It is best if you can always be on the stop through the 60' timer so you have something that should stay constant run-to-run.
S/ST 51
S/C 53
Old 06-02-2020, 10:37 AM   #7
StompNDump
What would you recommend Lenny? Throw me some numbers and ill try them this weekend if i get to test.
Old 06-02-2020, 05:40 PM   #8
Keith 944
Keith 944's Avatar
I totally agree with this
was going to mention this. i like a min of 2 sec duration on stop. ratio will be better and should be more consistent.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 06-02-2020, 05:43 PM   #9
Keith 944
Keith 944's Avatar
just bring the rpm up somewhere around 44-4600, see where you are, then if more needed bring the first (on) time out to maybe .5-1 sec
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 06-03-2020, 08:26 AM   #10
StompNDump
Ok Ill give this a try next time out with upping the RPMs to 4400. Would 300 RPM make a big difference?
Also Ill change Timer A1- to 1.000, would this be too much ?
