Liked 99 Times in 49 Posts
Any one out their had a oil filters collapse ? I have had the oil changed in are street car at the dealership, . since we are on lock down I thought I would do it my self.This is a 2013 2.4 chevy equinox with 70000 miles on it. Have not had any trouble with it. this time when i pulled the oil filter out it looked like a squashed. All used 5/30 gm dous.
Any thoughts |
#2 | |
Liked 1,916 Times in 574 Posts
Mike Pearson 2485 SS |
Liked 134 Times in 28 Posts
Jim;
I've seen this happen more then once and usually around this time of year when the temperature is in the 20-50 degree range. Street oil filters have a tighter mesh than racing filters and if the engine temp doesn't get the oil hot enough to evaporate moisture in the oil from a stuck open thermostat or just too much short trip stop start driving, the moisture will eventually plug the filter media. The oil pump pressure is trying to get oil past the plugged filtering element which distorts inside the filter shell. This can also do bearing damage and will show lower oil pressures if you have a gauge and not just a low pressure oil light. This is why lots of very short trip driving can be really bad on maintaining oil quality. Also see the attached link for additional information with illustrations about this problem. http://knowhow.napaonline.com/what-c...lter-collapse/ Last edited by Chuck Gallagher; 03-27-2020 at 08:54 AM. Reason: New additional information |
Liked 89 Times in 28 Posts
If out of warranty go with a Wix or Napa filter.
Glad you’ve not had any trouble with it. We had the same year, engine, but less mileage. It used oil like you wouldn’t believe. Rings were sticking in the pistons. |
Thanks for the replys. `I wondered why the filters where from 2.70 to 20.00 I will be using the better ones from now on. The 2.4 engine are not much good i find after buy one.
Liked 3 Times in 1 Post
All good info. The early 2.4 GDI motors really had problems and had to have the oil companies come to the rescue with DEXOS. Oil quality and change frequency is super important now with Variable Valve Timing and Variable Valve Lift technology. Any kind of debris will plug the tiny holes will make lights come on and cost money.
As an outside salesman I bought a new 06 HHR with a 2.4 (non GDI) for the mileage and its workability . My recipe was AC Delco (Hengst) oil filters and Mobil 1. I drove it 368k before a box truck with a lift gate backed into it and totalled it. |
