#21 |
Liked 254 Times in 78 Posts
I run a 305 chev 2bbl in a 3650 lbs car. I use Lakewood slappers with Lakewood adjustable shocks set a 50/50, monoleaf stock springs. Works great, never spins, consistent 60 foot times.
Mike Moller NHRA 203 Q-R-T/SA |
#22 | |
Liked 55 Times in 17 Posts
1967 Fairlane A/Stick - 1994 Mustang GT. 1989 Oldsmobile, R/SA - 2016 Z06 Weekend Street Car. |
#23 |
Liked 19 Times in 5 Posts
all the spring does is hold the car up off the ground,,,a leaf spring is a leaf spring,,,however,,,if a spring is too stiff,,as in a multi leaf spring,,,thats where the problem begins. You always want to use the weakest spring that will suspend the car. If a mono wont hold up a heavy car,,,,then look at removing leaves from a multi leaf. If the spring is to stiff,,,, no shock adjustment,pinion angle change is going to overcome the stiff spring,,,,ask me how I know,,,,,just kidding,,,,dont ask
#24 |
carbuilder,,, the rear of the spring, behind the axle is what holds up that car, and sets the ride height. The front of the spring forward of the axle is where we control the launch of the car. This is why Calvert springs are two piece. They are the best bolt on springs available for a stocker in my opinion. Springs can be custom made but this is all they are doing now. The bars are great. Now the front half of the spring and the shock tuning are where the real advantages are with a leaf spring car.
#25 |
Liked 2,753 Times in 974 Posts
Herb McCandless would be a great source of information on leaf spring technology.
Also, remember the Chrysler Leaf Link used on Ray Whinery's Dart? Last edited by Frank Castros; 03-17-2020 at 06:58 PM. |
#26 | |
#27 | |
There are many manufacturers of custom strings that are multi or mono leaf that do the same thing. I just like the Calverts because you have more adjustability. Want to change the ride height, buy the rear half. Change the "Hit" for an auto or stick car, buy the front half for that. I am not saying your wrong, just that Calverts are better. Little harder to change the whole spring vs. the front half. Other custom springs may be cheaper, I don't know the pricing differences. A tuned system is usually better when all of the components are used together.
#28 | |
If spending money that is not needed makes one happy,,,go ahead and buy the expensive stuff if that makes life easier,,,, but I can tell you from experience its not needed. As I said earlier,Keener doesnt use them,and he pretty much can buy what he wants,,,but he has a STOCK spring for a reason,,,and his cars are as fast as they get he has those for a reason |
#29 |
Liked 33 Times in 17 Posts
After looking at Merc's car at Indy year before, it looks like they are using a modified slapper.
#30 |
Cal tracs,ladder bars,four link,,,,modified slapper??? all traction devices,,,,I thought the question was about springs,,,, you guys keep your ball,,, Im going home
