Old 02-19-2020, 03:49 PM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Grade points
Can Grade points from super street be used to get into an national event in stock or super stock?
Adger Smith (Former SS)
Old 02-19-2020, 04:07 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,918 Times in 576 Posts
Default Re: Grade points
I am pretty sure that you can use your grade point in any class that you have a license or permanent number for. But you can only use them in one class. If you have 8 and enter say Super Stock. Then your points are used up for that event. You can’t souble enter unless you have enough to do that.
Mike Pearson 2485 SS
Old 02-19-2020, 04:32 PM   #3
Hacksaw
Liked 309 Times in 173 Posts
No. You would need at least one grade point in the class you wish to enter and with your SST grading points added in you will have a combo rating.
Hacksaw is online now   Reply With Quote
Old 02-20-2020, 08:15 AM   #4
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
I don't think that's accurate. I entered SS 2 years ago at Norwalk because stock was full. I've never had a SS GP....ever.
Jon Sarrett
Stock 3779
Jon Sarrett is offline   Reply With Quote
Old 02-20-2020, 09:47 AM   #5
jmcarter
jmcarter's Avatar
Liked 3,174 Times in 971 Posts
Jon and Mike are correct.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-20-2020, 09:50 AM   #6
Chip THELEGEND Johnson
Liked 281 Times in 79 Posts
According to Cody Savage SST, TS, TD grade points can be used to enter ST,SS,SG,SC. Grade points from those 4 classes cant be used to enter the other 3.
Chip THELEGEND Johnson is offline   Reply With Quote
Old 02-20-2020, 10:49 AM   #7
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
That is correct. Since SST, TS, and TD are not contested at every national event, only grade points earned in those classes may be used to enter.
S/ST 51
S/C 53
