#11 |
Also many race style headers are multiple tube, and need to be installed 1 piece at a time. Take a look at the headers on most 390 & 428 Mustangs and Fairlanes. No way to install those headers if they are all 1 piece, (hell, its a major PITA, even with 8 separate tubes!)
#12 | |
Liked 285 Times in 87 Posts
#13 |
Liked 355 Times in 80 Posts
#14 |
Liked 24 Times in 13 Posts
Not long after the "tether" rule came into effect, at a race in Epping, a guys "tether"
came off.There is even a video of that some where! The next thing will be a "tether" to hold the "tether" on!!! Then a "tether" to hold the "tether" to hold the "tether" .................... Terry K |
#15 | |
Liked 806 Times in 246 Posts
#16 |
Liked 280 Times in 139 Posts
How long has this "weld-on" tether been accepted?.I thought the reason for using the T-bolt clamp on the pri.pipe and collector was to prevent the old style tabs with 1/4" bolts and lock nuts from breaking off at the weld and the collector coming off.I know you still use the original tabs too, but how is this any better?...gsa612
#17 |
Liked 125 Times in 40 Posts
So lemme get this strasight......you’re on the forum, telling everyone how knowledgeable you are in manifold/head engineering, but can’t figure out the header tether rule?
Sean Cour T6066 ladle Last edited by Sean Cour; 02-02-2020 at 10:05 AM. |
#18 | |
Liked 167 Times in 81 Posts
Tim Schmackpfeffer 762 SS |
